Question about Car Audio & Video
Kd-r310 jvc wiring pin ids?
I need the wiring ids for new wires but dont know which pin is what?
JMuskovitz
  • 135 Answers
SOURCE: JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
j_del
  • 1586 Answers
SOURCE: wont keep memory
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Posted on Jul 23, 2008
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
Hi,Excuseme.I have 16 pin connecter of the JVC KD-S575. But,color of the wires does not match the position of the pin.I want to know the position of the 16 pin connecter of the JVC KD-S575 It has 2...
Car manufacturers donot keep color code. Your best bet is to order a universal adapter. JVC color code can be found in the instruction book. I will attach a picture. upload is not working. email me to jpulickal@gmail.com
Oct 02, 2013 | JVC KD-S570 CD Player
How do I set the color on my JVC KD-R310 ? I already lived through the 1970s. I don't need the disco lights effect in my car.
push the color button when the display light's up you can choose between one color for the button or one color for the display by turning the volume button and choose which color fit's your liking when u find your color push the volum button. that should help you out on that part.
Apr 24, 2011 | JVC Kd-r310 Car CD/ MP3 Player
My manual is gone and i dont know where to connect this brown wire, blue wire. orange wire. red wire. yellow wire black wire. may you give me the details where to connect these wires pls,,
Here is a link to the manual that will ID all the wires for you and what they do.
If your not 100% sure of what to hook up or how to hook it up, visit a quality car audio store in your area and have them do it for you.
http://resources.jvc.com/Resources/00/00/94/GET0247-002A.pdf
Feb 04, 2011 | JVC Arsenal KD-AR760 CD Player
Have a jvc head unit, where do I connect the steering wheel audio control wire? JVC KD R310, 2002 Nissan Maxima.
Do you have an adapter that converts the Nissan controls for the JVC? Typically this piece is specific to the car and required as a separate item. If you do have this piece, then typically one of the plugs you removed from the factory stereo but aren't currently using will plug into the control adapter unit and then it will have an output wire to connect to your JVC.
Aug 09, 2010 | Car Audio & Video
Jvc KD-G210
Did you know there is a fuse on the back of the radio and one on the amp? Have you checked them? If the radio is working and no ssound it could be the radio, speakers or wiring. In your case it sounds like either the radio or speakers.
Sep 22, 2009 | Car Audio & Video
Dont have wires
I had this same problem with a sony deck. Try ebay and search wiring harnes for JVC KD-SC500.
Jun 02, 2009 | JVC KD-SC500 CD Player
Mar 29, 2007 | JVC KD-S640 CD Player
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
