Question about Dell Dimension 2400 PC Desktop
How to replace the password jumper
I was trying to remove the password on the cpu.I was reading the owner manual and it said this can be done by removeing password jumper. I was trying to do this and broke the jumper in two pieces(top&bottom). How can i fix this.
  • 62 Answers
Make a wire bridge and short the terminals it should reset the bios to no password
Posted on Feb 25, 2012
Dude, Can you send me a Bootable ISO CD of Dell Asset/Service Tag BIOS Reset Tool........Please
Hello, you can download this tool here:
http://www.cgsecurity.org/wiki/CmosPwd
Dell
The official method is to contact Dell Technical Support. Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Latitude. If the current user is not the original Latitude owner, Dell will transfer the used Latitude's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
  • Dell Inspiron 5100: eeprom 93lc46, password in scan code at 0x310
  • Dell Inspiron 7500: eeprom 24c164
  • Dell Inspiron 8100: eeprom 24c02
  • Dell Latitude C600: eeprom 24c02, password in scan code at 0x00, 0x10 and 0x90
  • Dell Latitude C610: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80 and 0x90
  • Dell Latitude C640: eeprom 24c04, password in scan code at 0x100 and 0x180
  • Dell Latitude CPI: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80
  • Dell D600: eeprom 24c04, password in scan code at 0x110
  • Dell Optiplex: Remove the PSWD jumper
  • For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
    • Locate the 3-pin CMOS password reset jumper on the system board.
    • Remove the jumper plug from pins 1 and 2.
    • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
    • Replace the jumper plug on pins 1 and 2.
Try the backdoor password: Dell
The another method is: by Using the Motherboard Jumper: In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off, and remove the battery and power cord
( if it is a laptop ) before you continue.
Here is a picture how it looks like:
The default setting is:pin 1 to 2, to clear cmos: 2 to 3.
Best of luck :-)
Feb 05, 2013 | Computers & Internet
I am using via cn896 motherboard and i have set bios password, right now i forgot that what password i have given, than i try to clear the password doing remove the cmos battery but still password is not...
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
Mar 25, 2011 | Biostar Viotech 3100+ VIA CN896 mATX...
I removed the network ic and had a jumper but it has no network i tried to find manually but did not get network and even i changed a battery adapter also but no use
If the jumper you have done is correct then the problem occur from CPU. So try to give some light heat or replace .Good luck
Aug 07, 2010 | Nokia 1100
A friend has an Acer Aspire 5341 and needs to reset the bios password. Now, she said she had taken out the "bios battery", let it rest for a bit and then placed it in again but this did not work. Any help...
it is not only about removing the battery and replacing it.there are other steps to be taken.Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
Make sure to turn the PC off before opening the cabinet and resetting the jumper. another option is by using a software the BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds.vote me if this works for her.best luck!
Jun 17, 2010 | Acer Aspire 9300-5349 Notebook
How to remove bios password in lenovo 3000 y510
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Jun 10, 2010 | Lenovo IdeaPad Y510 Notebook
Unable to reset bios password - removing coin cell battery had no effect
Then you can try it out by removing the jumper.
The location of this jumper varies depending upon the motherboard brand.You should read your motherboard
manual to check its location.If you don't have the manual then look for the jumpers near the CMOS battery.
Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS etc.When you find the jumper,look carefully.
There will be 3 pins and the jumper will be joining the center pin to either left or right pin.What you need to
do is remove the jumper and join the center pin to the opposite pin.e.g.if the jumper joins center pin to left pin
then remove it and join center pin to right pin.Now wait for a few seconds and then again remove the jumper and join
the center pin to left pin.Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Feb 02, 2010 | Dell Inspiron 1501 Notebook
I forgot BIOS password for SONY PCG-GRX520
The best way for the Sony is to remove the cmos battery for at least 30 minutes. Remove the main laptop battery and leave it out. Make sure the power adapter is not attached. The cmos battery can be reached after removing the keyboard and is attached to the motherboard vis a small cable. If you have a "jumper" that come equipped on hard drives to jump the pins on the back, you can "short" the pin connections on the cmos battery socket, power the laptop up using the ac adapter and letting the computer go through the bootup process. When this happens power the laptop back down, take the jumper off and replace the cmos battery. Power back on with just the ac adapter and boot the computer. If the laptop still askes for a bios password just hit enter and it should allow you to log in. Once in go into the bios and reset the date and time. Once that is done power down and replace the main battery. Reboot the laptop and let Windows load.
Nov 18, 2009 | Sony VAIO GRX520 Notebook
Don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
Dell D505 BIOS Reset
Generally, all you need to do is get on to Dell Support and get in a chat with one of their people and tell them that you are locked out by a BIOS password, and needed to get around it. After they verify that you are the owner of the laptop, they should give you a password that gets you through it.
Apr 28, 2009 | Dell Latitude D505 Notebook
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Jun 24, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
