Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
Projector is not able to project red from the vga cable
If i use the vga cable from the computer it will not show reds. (the pop-up menu will show red when the red is adjusted in the menu) But if i use the s-video port, reds are shown crisp and clear! do you think this is a VGA cable problem, or is it a problem inside the projector? i have tried the connections on multiple computers with the same result, but i have not tried to change the cable. ($50---HA!) i would think this projector has only one video card that supports both VGA and s-video ports and therefore if it was an internal problem, it wouldnt work on either!? OH--and the cable pins are ok. Thanks
    Novelist:
    Champion:
  • 254 Answers
I assume connecting a monitor/lcd panel display doesn't exhibit the missing red? To narrow this down, try using the cable with either a different projector or monitor/flat panel display. In short, does the problem follow the cable to these other devices? If so, then even though there are no pins bent over, the cable is probably bad. Cables can develop an internal connection break, even without showing any external evidence. This will usually occur at a connector end, and is often the result of overflexing, bending or other straining of the cable near the connector. Can you borrow another cable from a friend? A couple of other possibilities: 1. A broken solder connection at the VGA jack inside the projector. This can occur, again, if the connection is stressed (flexed, jammed, pulled on etc.). 2. The circuitry just beyond the VGA jack, which processes the video information could have a defect, not passing the Red info. The latter problem is one for a capable technician, and depending on expertise, you might be able to repair a broken solder connection.
Posted on Feb 15, 2007
My Epson EMP-S1 projector shows pink color with VGA input only, ok with video input and menu screen. What can be the problem?
With the VGA you have a bad cable or a bad input jack. I would bet on the cable first. You are missing the green or the blue on the screen and that is why the red/pink is more pronounced now.
Oct 04, 2012 | Epson EMP S1 Multimedia Projector
Our club owns a Canon LV-7240 which has worked OK. Last night we showed an NTSC DVD from Europe and no red showed. We could see what the colours ought to be on the laptop screen. On the big screen,...
Can't answer for the menu issues, but I can garuntee this is not a problem with brightness, contrast or sharpness, and very unlikely that you'll find a solution in the menu. What is likely is that the VGA wasn't plugged in properly initially. When the signal is going down the VGA it's broken up into 5 seperate signals, Red, Green, Blue and 2 sync signals. What is likely is that the green and blue pins havn't properly made contact either inside the projector or inside the laptop. This would also explain why it worked when you tried later because it made the connection properly. I would suggest trying again with the same laptop, if it does it again, try another PC without moving the projector or the VGA connector that's plugged into the projector. This will atleast narrow down your problem, but it doesn't sound like a problem with the projector to me. Also try plugging the laptop that wasn't working properly into a monitor (this will test the laptop)
Mar 25, 2011 | Canon LV-7240 Multimedia Projector
The color of the presentation is distorted when it is projected from the BenQ DX660 Projector. It looks like the red is not coming through.
I I may have you try a simple test first, I have seen several no red problems fixed by changing or wiggling the vga lead to the computer. Also look for bent gold pins on the vga lead. I would do that first. Also go through the menu system and see if there is red in one of the icons on the screen to see if it is showing correct colour.
Good Luck!
Dec 17, 2009 | BenQ Replacement Lamp Projector Lamp For...
No Reds , replaced VGA cables, interface, projector bulb, still no reds.
One of the pins on the 15 pin VGA cable had been folded over in half. Proved the computer and cabling worked with another projector. Reinvestigated the connections wired into the ceiling to the projector and discovered that the VGA cable in the wireway had been damaged slightly. Bent and straightened the number one pin on the vga cable and everything is fabulous.
Nov 05, 2009 | Mitsubishi XD500U-ST DLP Projector
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
Red does not show up
You have a break in the VGA feed to your projector, try another lead and try menu see if it is missing from there if not it is the lead.
Marc Engineer
Feb 13, 2009 | NEC VT570 Multimedia Projector
Red color absent from projector picture
try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Nec projector vt590 doesn't project RED
Red, Green, and Blue signals come from different wires in the VGA cable.  This sometimes happens if a cable simply is not connected fully.  But it will also happen if the cable is damaged.  The damage might be visible in the form of a bent, broken, or missing pin.  Or it might be internal to the cable.
Try another cable.
If that's not it, then the connector on either your computer or on the projector itself might be damaged.
Also try another computer.
Components inside the projector could also fail.  But I'd bet on a cable problem any day.
Nov 24, 2008 | NEC (MTLAMP820/1020) Projector Lamp for...
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
1,524 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
