Question about Brother MFC 7840W Printer
Printer offline Printer says offline but it was working just fine yesterday.
  • 2 more comments
  • Grant D. Feb 24, 2012
    What operating system are you using?
    If its windows, go to the start menu, then Control Panel. Click on 'view devices and printers', right click on your printer and click on 'see whats printing'. Click on the printer option on the menu bar: if the 'Use Printer Offline' option is checked, then UNcheck it. Let me know if this helps.
  • christine cambensy Feb 27, 2012
    I'm using windows. The Use printer offline option was unchecked already. My problem is that my printer itself says its offline and I'm unsure how to make it go online so I can use it to print
  • Brian Feb 27, 2012
    Id start with turning the printer off, then turn your pc off as well.turn the printer on, then turn the pc on. make sure its a full shutdown and not just a sleep or hibernation.let me know if youve already tried this as well.
    Top Expert:
  • 1,575 Answers
Hi
Try disconnecting the printer completely from power and from the PC.
Leave it as such for one hour.
Connect the printer again.
Check the connections and make sure its well connected.
Posted on Feb 28, 2012
Says printer offline
"Offline" means it can't connect to the printer. Check all the wires from computer to printer, unplug and re-plug. Unplug printer from wall, wait 30 seconds, plug back in. Make sure printer is on.
Oct 16, 2014 | Sharp MX-2300N Color Copier
My brother hl 5250dn says its offline. How do I get it back online? I am using windows 8.1
Since you mention internet issues that your carrier fixed, I'd look at your local router. The router provides IP numbers to all the devices in your home network and if its been replaced or even reset, its likely offering up a new (and different) ip number to your printer. Try creating another printer object on your windows computer and see if windows can find the Brother connection that way. Windows won't scan for a changed IP number on a printer its already configured. If that fails, you can use the router to show you all the devices it sees on your home network and check to be certain the printer is present.
--jm
Oct 07, 2014 | Brother HL 5250DN Laser Printer
Error message that my IP90 Canon is offline.
Check that you haven't accidentally changed it setup to being off line, you will find this in the devices section of the control panel. If that doesn't work I suggest you re-install the printer software using the setup disk that should have come with the printer. Hope this helps.
Dec 30, 2012 | Canon PIXMA iP90 Mobile Printer
Printer says '' error- offline" everything is hooked up worked fine yesterday and last 3 years
is the correct driver installed? also is it plugged in to the same usb port? Visit the manufactuers website and update youre rivers but do it while the printer is unplugged then plug it in
Sep 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Cannon MultiPass MP730 printer/scanner is offline
Try reinstalling the software if on canon.com website.
Apr 02, 2009 | Cannon EOS 50D Digital Camera
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Printer is offline.
hi iam kishan from india do one thing if u have a driver cd of your priner disconnect printer and go to control panel clik on add/remove program remove all driver oand sofftware of your printer and restart ypur pc and after restarting insert cd in install software of your printer do no connect printer untill computer want or connect after finnish i
Jan 12, 2007 | HP Deskjet F340 All-In-One Printer
Brother MFC 7840W Printer Logo
290 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
