Question about Radio Shack TRC-503 CB Radio
Keying the mike
Hello ! I HAVE A MIDLAND CB RADIO IN A TRACTOR WITH A MAGMOUNT ON THE ROOF. WHEN PEOPLE ARE ON THEIR SPEAKING THE TX BAR MOVES UP TO 8 DIGITS BUT WHEN I KEY THE MIKE MY TX DIGITS ONLY MOVES UP TO 3 OR 4 . I HAVE DISCONECTED THE AIREAL FROM THE BACK OF THE CB THEN KEYED THE MIKE AND IT MOVES TO 8 BUT JUST NOT WHEN THE AIREAL IS IN THE BACK ( WHAT IS THE PROBLEM ????????????
  • 204 Answers
Hello Adam, first off, do not unhook the antenna then key the mic; you run the risk of blowing the final transistor out of the radio, then it will not TX.
The digital TX lights can be adjusted high or low by a cb tech. All they are is a general reference as to how much power is being dead keyed; usually around 4 watts.
For the best performance, the antenna needs to have the SWR set with a meter so all your signals are getting in and out. A mismatched antenna system can lose you about half of your power and range; and that's hard on the radio also.
If your radio was tuned up by a shop tech, you would see the digital go part way up, but when you talked into the mic, the digital would go almost all the way up. I hope this clarified the situation for you,,, Let me know,,, Mechanic
Posted on Nov 01, 2008
I have a midland 77-151 it powers on but it doesnt transmit or recive the tx lights dont light up and the need on the metter doesnt move when the mic us keyed either.
I am sorry I am notfamiliar with this brandof radio.,so must askyoutoexplain further what the problem is.
That is if you cannot solve it with a new fuse, sometimes they do not need more help than that.
all the best
Kolbrun
Mar 06, 2012 | Midland Radio Communications
When i turn on the midland 100m cb, I don't hear anything. The antenna is connected. Even when I key the mike, the needle doesn't move.
What about the Microphone you are using---Is it the right one for this model? If its not a Mic problem then its a burnt transistor in your board. Keep trying something with the Mic. May have to get it serviced at a repair shop. Sorry,can't help much.
May 07, 2011 | Midland Radio Communications
Squeals when mic is keyed
was the mic working before or is it a diffrent mic cause it sounds like a the mic is wired wrong audio lead and tx wired wrong way round.
Jan 25, 2011 | Midland 40-Channel CB Radio CB Radio
I cant be heard when i speak through my midland 1001z cb radio?
hello have you checked the swr on the antenna have you checked the output of the radio with a power metre it should be reading 4watts max if yes problem might be the microphone make sure there are no wires shortening in the mic socket entering the radio and check inside the mic aswell
cheers and goodluck
Jun 26, 2010 | Midland 1001Z 40-Channels Base CB Radio
Midland 5001 40 channel cb radio all is fine with the radio except I question one thing there is a chirp that occurs just before the key down it chirps first then keys up and talks fine. Is this something...
Hi Tom
Ya know I have that same radio with the same chirp. I have asked many to tell me if they hear the chirp on the air and no one has heard it but me. I know what it is but i wont fix it due to the fact it is the only radio that does that to me and i think its kinda cute for it to do it. Now to let you in on the secret is that for the radio to go from rx to tx is handled by transistors plus the computer has to give final say so to tx. So the chirp is developed by the switching and computer turn around times to allow you to talk. I hope this helps.
Ray
Jun 13, 2010 | Midland 5001 40-Channels Base CB Radio
When driving over rough ground my midland alan 48 plus multi cb will sometmes change channel on its own i wondered if this could be a mike problem as you can change channel from the mike
Check for loose buttons, could be something loose inside, if its changing on its own when its moving around could be from vibration that something has come loose.
When parked just try shaking the mic first if that doesnt do it shake the cb itself and see if the problem persists
May 18, 2010 | Midland Radio Communications
Midland 77-250k No RX nothing, TX perfect on
Best course of action is to ship it in. www.Dodgem250.com
Apr 10, 2010 | Midland 77-250CXL 40-Channels Base CB...
Midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
Aug 16, 2007 | Midland 75-785 Handheld CB Radio
Radio Shack TRC-503 CB Radio Logo
127 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
