Question about Emerson Smartset Clock Radio
Turn off the DST
My Smartset Clock Radio exists in zone 7, Hawaii. We do not have DST and I would like to turn it off or set the start and stop date for the same day?
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Mar 15, 2011 | Emerson SmartSet CKS1850 Clock Radio
Tip
Daylight Saving Time Changes for SmartSet Clock/Radios
Dear Emerson SmartSet® Clock/Clock Radio Owner:
Your Emerson SmartSet® Clock or Clock Radio includes Emerson’s patentedAuto Time Setting System that
automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and
after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and
alarm settings for up to 5 years, or even longer.
As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/
Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into
all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight
Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April
and ends on the last Sunday in October.
The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to
extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in
March and end on the first Sunday in November.
Of course this is a situation that is beyond the control of Emerson, or any other company that produces
devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA’s, and
many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to
make adjustments to the automatic DST software to agree with the new DST timing for 2007.
Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It
would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows:
1.) On the second Sunday in March you would have to set your clock to the next lower number time zone.
For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone
1 to move it ahead by one hour.
2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the
clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set
your clock back to Zone 02.
3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone.
4.) On the first Sunday in November you would again set your clock back to your correct time zone.
Instructions for changing the Time Zone setting are found in the Owner’s Manual.
We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
Printed in China
508-02
on Jun 13, 2009 | Emerson Smartset Clock Radio
Daylight savings time changes at wrong date on my brookstone 'smartset' alarm clock. (It changes at the old date, of course - so it is wrong 4 times a year...)
The DST schedule is hardwired into the older clocks and cannot be modified to run on the new schedule. If the clock has a DST switch, you can can turn it OFF and reset the clock only twice a year. On my old "ATOMIC" clock, I've set the DST function OFF, and I use the time zone switch for my adjustments. Sorry, but your only other choice is a new clock.
Bill B
Apr 05, 2010 | Brookstone SmartSet CD Alarm Clock Radio
How do I disable the Daylight Savings Time function? the dates for DST have changed and the alarm is still set to the old date changes.
See the comments under Petewete. There is no way to disable it on the T301B model. Changing time zones doesn't help because all 7 zones observe DST, or at least they did before 2005. (Now Hawaii Zone 7 does not). I know because I tested all zones. The workaround is complicated: before each time change, pretend it is the old DST date (1st Sunday in April or last Sunday in October) by resetting your date. My spouse says to fix the problem by hitting the snooze button with a 20-pound sledge hammer.
Oct 25, 2009 | Timex Auto-Set Dual Alarm Digital Clock...
How to reset Emerson SmartSet AC100 Alarm/Radio for DST changes!!
No way to change it to automatically do it without replacing the data chip. I changed the time zone from 3 to 2 in the fall and then have to switch back to zone 3 in April.
Apr 03, 2009 | Emerson Smartset Clock Radio
Daylight Savings Times Changed
We set the time zone to '7' , which is Hawaii time zone where there is no change for daylight savings. This came up because it changed automatically on this morning...and although we can change it back, then it won't change next week when it should. So we're hoping that by setting it to Hawaii it will be a regular clock, we will do the changing...but at least we won't be surprized as we were this AM.
lb
Mar 09, 2008 | Emerson SmartSet CKS1850 Clock Radio
Help daylight savings time is not here yet
I am going to try changing to time zone 7 (Hawaiian Time). Hawaii does not observe DST so this should turn the clock into a regular clock that ignores DST and you need to set yourself twice a year.
Oct 30, 2007 | Emerson SmartSet CKS1850 Clock Radio
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Oct 29, 2007 | Emerson Smartset Clock Radio
Emerson Research SmartSet Clock Radio
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Oct 28, 2007 | Emerson Smartset Clock Radio
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Mar 06, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Emerson Smartset Clock Radio Logo
140 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
