Question about Dell Inspiron 600m 1.6GHz Pentium M Notebook (162891033) PC Notebook
Inspiron 600m USB ports stopped working
Looking in hardware devices the USB ports all indicate working properly; hoever, the ethernet controler has a big yellow "?" indicating an issue there
  • Dell Master
  • 32,281 Answers
I recommend you install the latest USB and LAN drivers.
You can download the device drivers from Dell WEB site,the support download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows of the drivers for your Windows operating system. Click on thislink to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Feb 25, 2012
scanner077
  • 52 Answers
SOURCE: i lost my dell inspiron
Hi!
Please go to this site for your driver needs: http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=5&impid=-1&servicetag=&SystemID=INS_PNT_PM_600M&hidos=WW1&hidlang=en&TabIndex=
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Posted on Dec 31, 2008
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
  • 479 Answers
SOURCE: 1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Posted on Jul 27, 2009
gsimon5661
  • 98 Answers
SOURCE: Where do I get the ethernet controller driver for
I have good news I do own a dell inspiron 600m, i just went to confirm, i see the drivers right at the dell support and download pages, try this link http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=INS_PNT_PM_600M&os=WW1&osl=en&catid=&impid=
when you get there either by following the link or going to dell support choose the Broadcom 440x 10/100 Integrated Controller link under all the downloads. Click download now and not add to my download list. you may also try this link http://support.dell.com/support/downloads/download.aspx?c=us&cs=04&l=en&s=bsd&releaseid=R85255&SystemID=INS_PNT_PM_600M&servicetag=&os=WW1&osl=en&deviceid=2966&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=111674
I would also save the file to my desktop rather than installing it directly from the web, just a preference of mine. hope this works for you.
Let me know.
Posted on Oct 07, 2009
  • 72 Answers
SOURCE: Pls i need dell inspiron 600m ethernet driver
You can find the driver on dell support site.I have provided a link below, just visit it and download the driver.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R107518&SystemID=INS_PNT_PM_600M&servicetag=&os=WW1&osl=en&deviceid=2967&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=139326
Posted on May 01, 2010
Why don't my Dell 600m USB ports work?
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/inspiron-600m
Look for any drivers missing, in the device manager.
You will probably need, the chipset driver, to make the usb port work.
You will also need service pack 1, to support the usb function.
Good luck
Jan 20, 2013 | Dell X2033 - Latitude D600 D500 Inspiron...
Usb wont work
check this things
1.make sure the minimum hardware and operating system requirements of the hardware to be installed are met.
2.just make sure the latest bios code is installed.
3.then make sure the usb is enabled in the BIOS. power on the system, press f1 to access the system configuration utility.click devices and i/o ports and then click usb.
5. make sure the usb controller and hub are listed in the device manager as will as any installed devices for the usb option.
6. then you can try the device in all available usb ports.if it works in other usb ports, the non working ports probably defective.
Nov 04, 2012 | Dell Inspiron 570 Desktop PC (I5707163PBK)
I have a Dell Inspiron 600m. When I turn it on it goes through the Dell startup screen and then a black screen appears with a blinking curser. That's where it stops. Tried reinstalling Windows XT but...
there are steps to resolve this issue ...
first of all remove all the usb devices and start the system and it should go to the desktop
shut the system back and start the system on the dell logo start tapping the delete key and that will take u on the bios screen there u will find USB emulation put it to no boot and save and exit and restart and than connect the devices to the system ... restart to make sure its working fine
Jan 22, 2011 | Dell Inspiron™ 600M PC Notebook
My Dell Inspiron 600m will not connect to the Internet using DSL.
I see..if you are trying to connect it using an external modem...and a cable connection ...you probably have to install the right driver for the ethernet card ..if you use this port ...by default sometimes it gets from the windows the right driver ..but only for a few common network cards ....and it is a vry big chance that it installed a wrong driver and you do not use it and not needed it until now ...so ..
anyway ...if you use an internal modem it is probably the same problem ...you can find the drivers for network here ......there are for XP os ..
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_PM_600M&hidos=WW1&hidlang=en&TabIndex=
but ...better go to device manager ...scan for hardware changes to see what drivers are missing ...exactly ...keep in mind that they may appear installed ..but not have the right driver for it ...but another one installed by windows automatically ...
after the drivers in place ...for dsl ...just choose to get an ip adress automatically fromn the tcp/ip protocol...and will work ..
Jan 10, 2010 | Dell Inspiron 600M Notebook
USB ports do not work
1.) Check your CMOS/Bios settings to see if any USB ports are disabled.
2.) If not, check to see that USB ports show in your operating system's device manager or settings. Enable them if they are disabled. Otherwise, you may need to reinstall the drivers that came with your model of notebook computer.
If using Windows XP, for example, go to Control Panel, System, Hardware, Device Manager, Universal Serial Bus Controllers. If the latter is not present and you have USB enabled in CMOS/Bios, you will need to install the drivers. If "Universal Serial Bus Controllers" is present, look within to see if they are all enabled and working properly.
If not, re-install the drivers.
3.) If the above does not work, you may have bad USB ports that will require service by an authorized repair service for your notebook computer.
Oct 16, 2009 | Dell Inspiron XPS M140 Notebook
Inspiron B130 USB Ports Not Working
Try going into control panel and then system and the hardware and then device manager look for the usb ports and delete them, then reboot the system ,they should be there.
May 31, 2009 | Dell Inspiron B130 Notebook
USB Audio Controller and Interface Won't Install on Dell 600m
This is generally caused by a driver conflict. Uninstall the sound drivers for the built in, then try to install the sound drivers for the RMX. If the hardware wizard finds and tries to install the drivers for both sound cards there may be a conflict, due to the drivers for the built in still being in the drivers cab file, then you will have to completely delete the driver file manually. Once you get the RMX drivers to load, you may have to create a seperate sound profile for the RMX, and switch to it manually when using it, in order to keep from creating a conflict between the two.
Jul 09, 2008 | Dell Inspiron 600M Notebook
Ethernet port is not working
check in the control panel... system > hardware > device manager... make sure your Ethernet has the right driver and installed properly... do this before poking and opening your laptop =)
May 31, 2008 | Toshiba Slim Port Replicator II
Computers & Internet Logo
145 people viewed this question
Alun Cox
