Question about Tools & Hardware - Others
Can the carriage on a dewalt dc618 nailgun be adjusted
The nails keep jamming
  • 1 more comment
  • anthony green Feb 28, 2012
    I have checked the carriage and it is clear and I'm using the proper dewalt nails .batteries are charged still keeps jamming
  • Repair Ahjoshe Feb 28, 2012
    You may have a bent, broken or worn driver blade. The driver blade is inexpensive to replace, part number 624742-00SV for about $25, but the gun's insides are very compicated and I would caution agianst going inside the gun unless you're very mechanically inclined. If you are not a service center may be in line.
  • anthony green Mar 27, 2012
    Can the depth adjustment be made stronger by opening up the dewalt dc618 as the adjuster is at 6 the batteries are fully charged and the nails want go all the way in
  • 885 Answers
The only adjustment on nail guns is for the nail drive depth, the magazine is hard mounted to the nose piece. If you are having problems with the nail clips feeding, first make sure the entire feed path is clear of any nails, parts of nails or other foreign things. Then make sure the nails you are using are fully compatable with your nailgun. Your gun needs 16 guage nails set at a 20-degree angle no shorted than 1 1/4" and no longer than 2 1/2" long. Any deviation from those requirements will only give you a headache worse than what you have now.
Posted on Feb 27, 2012
4 Suggested Answers
  • 13 Answers
SOURCE: dewalt nailgun wont punch nails
dewalt nailgun jamming "constantly"
Posted on Oct 28, 2009
pranaclimbin
  • 50 Answers
SOURCE: dewalt dc618 wont drive a nail
its probably jammed. i have one of those and it tends to jam everyonce in a while. either that or the battery is dead. those two reasons will keep it from firing.
Posted on Dec 04, 2008
rcalorisian
  • 313 Answers
SOURCE: carraige in dewalt nailer
just goto:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
download the support manual. You should be on your way
Posted on Sep 08, 2009
MY NAILGUN QUIT FIRING NAILS. I LOADED UP TWICE AND USED NAILS BUT AFTER LOADING THE 3RD SET OF NAILS MY NAILGUN WON'T FIRE THEM INTO WOOD. WHAT I HEAR IS JUST A SMALL AMOUNT OF AIR FROM AROUND THE...
Sounds like you may have a nail jam. You didn't specify what type of nailer you have - most finish guns have a latch to open the nose & clear a jam - if it is a framer most of the time it requires a long punch and a hammer to push the driver back in past the jam to clear it.
Let me know if this does not fix your issue.
Nov 05, 2014 | Air Tools & Compressors
How to unjam a paslode nailgun
use the driver of the tool or an nail punch and a hammer to knock out the jammed nails
Sep 13, 2012 | Air Tools & Compressors
Dc618 brad gun wont fire on bump
The link below is where you can download the owners manual. The link is on that page near the top right hand side under the area marked downloads. Page 5 will show you were the switch is located that switches the tool from sequential fire to bump fire.
DeWalt DC618 parts and operations manuals
Jul 07, 2012 | Dewalt DC618KA Angled Nailer Kit
DC6t16 nailgun I have a nail stuck lengthways in the magazine. This stops loading nails. How can I remove it
The bestthing to do is get you a good screw driver and just sit down and start prying it out of there, will take a minute or 2 but will eventually come out
Jul 26, 2011 | Dewalt DC616 16g Cordless 18v Straight...
Nails keep jamming in the gun. how do you fix that and not sure about the correct air pressure.
Not all nails are exactly to gauge, but if they measure about right (take one nail off strip and see if it fits snuggly into bottom of nose) most likely the problem is the driver; missing tip or bent. Remove head and pull out driver. If just the tip is broken you can grind it square again and if bent you could try to adjust. If not driver is available at dewalt service center and at www.toolpartsdirect.com Good luck
Oct 09, 2010 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
I have dewalt dc618, nail doesn't goes all the way in, please help?
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Sep 08, 2010 | Dewalt DC618KA Angled Nailer Kit
Dewalt nailgun wont punch nails
Oct 13, 2009 | Dewalt DC618KA Angled Nailer Kit
My DC618 nailer won't fire .
Check the battey then take it out and check the driving rod. On the front of the gun, flip the latch and make sure it is pushed all the way back.
make sure you have nail, of course. put the battery back in. If al that does not work, have it services at a dewalt service center.
Aug 18, 2009 | Dewalt Tools & Hardware - Others
Dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Dec 04, 2008 | Dewalt DC618KA Angled Nailer Kit
Tools & Hardware - Others Logo
223 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
