Question about Samsung Microwave Ovens
Samsung smg 7187stg motor
The control panel sometimes work sometimes don't. Sometimes I push the buttons and any action can be performed.
localwonder
  • 6784 Answers
SOURCE: BUTTONS ON CONTROL PANEL DOESN'T WORK REGULARLU
HI, unfortunately, the actual part you need(Control board), has been discontinued. it is best to just purchase a newer unit in this case. This unit is not repairable at this time due to the unavailability of the components.
Posted on Aug 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung microwave MW1430WA often refuses to respond
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
You have a failing membrane keypad.
On some models, you have to peel off the old one and replace it.
On some models, you remove your controller and move your circuit board into a new frame with a keypad already installed.
FixYa is not currently notifying us when Clarification Requests are answered, so please contact me directly with your full model number from the tag on / in the unit and color so we can help you with free do-it-yourself tips and/or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2009
MicrowaveSvc
  • 9047 Answers
William E. Miller
prototech@usa.net
  • 142 Answers
SOURCE: My 7 years old dacor
The most probable cause would be a problem with one of the door switches. When it is not working shake the door up and down and hit "start" again. If that made it work, you would need to test the switches for proper operation.
Posted on Aug 09, 2011
Macmarkus
  • 2605 Answers
SOURCE: LMV1630ST microwave - the control
Hello, welcome to FixYa.
To address the issue you have, "LG" have a separate membrane/touchpad available for purchase as that is the most likley culprit, based on your description.
Posted below is a couple of link's to the part number and illustrations...of many locations you can purchase it from. Part # 350681A006A and retails for under $20US.
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Microwave-Parts/Model-LMV1630ST/3204/0123370?pathTaken=&prst=0&shdMod=LMV1630ST
http://www.repairclinic.com/PartDetail/Membrane/350681A006A/1517947
Hope this helps and thank you for choosing FixYa. Let me know if I can help going forward. Good luck.
Regards,
Macmarkus :)
Posted on Aug 26, 2011
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Control panel touchpad does not work; push buttons for Vent, etc. are ok and clock is working. Sometimes when I press the Vent button, I get a message saying the charcoal filter needs replacing. I looked...
follow this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2hVdoScpK
Oct 12, 2013 | GE SpaceMaker Microwave Ovens
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Oct 01, 2012 | GE Microwave Ovens
Maytag microwave keypad
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
My microwave start button doesn't push in to start my microwave
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
It's most likely that the keypad is worn out or possibly you have a flaky door switch.
We have full details, critical safety, disassembly, and troubleshooting info (as well as door switch testing info) at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually order Samsung parts (either the keypad / membrane switch or control panel with keypad) from http://www.samsungparts.com but that model number is not showing up, so you may have to call or e-mail them through their site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 27, 2007 | Microwave Ovens
Microwave Ovens Logo
21 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
