Question about Eton Solarlink FR600 AMFMWeatherSW Radio
Eton aolarlink fr600 is set to get weather alerts... There is an alert for my county, a tornado watch, but this radio does not show it!!!! What is wrong????
2 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: program county weather code
Sorry, but your radio does not have that feature, which is known as S.A.M.E. When set on ALERT your radio will receive all alert messages broadcast by the NOAA station that you are tuned to. The only fix, unfortunately, is to purchase a set that has the S.A.M.E. feature.
Bill B.
San Antonio
Posted on May 16, 2009
My midland wr100 is going off for the wrong county, sometimes not for a county that isn't even programmed!!!
Press the menu button once until you see "TIME", press the up arrow until you see "SAME SET", press select, you should have "SINGLE" selected if you are only wanting to get alarms on one SAME code. Press "SELECT" the screen should go to SAME 01, press select again and confirm that you have the correct SAME code entered. "MULTIPLE" will allow for more than one SAME code to alert and "ANY" will set the unit off for any SAME code alert.
Oct 17, 2012 | Midland WR-100 Weather/RDS Radio
Got a midland weather radio problem wr100 series. all county codes in and channel set. was working for awhile and now no alerts at all. keeps now saying check reception.
Turn your radio off and then on again. Then press the weather/snooze button. Do you hear the broadcast from your local transmitter? Check NOAA to make sure the station is broadcasting (not down for repairs). Try setting the radio to a different transmitter that covers your area.
You may need an external antenna for the radio (http://www.midlandradio.com/Weather-Radio-Accessories.BPE/18-259W ). Beware: when you use an external antenna, you may receive a broadcast from a different transmitter (farther away). In that case, the weather alerts for your county will likely not come in.
I hope this helps.
(we have two weather radios that are on full-time. The one set to a secondary transmitter does not receive the S.A.M.E. test signals or watches. (It can't be positioned to receive from the primary transmitter clearly.) It does receive warnings for the county correctly. The on/off routine has to be done every few weeks since it doesn't get the test signals. We tried an external antenna and kept getting transmitters from other states and missed tests, watches and warnings. Fortunately our main weather radio does get the primary transmitter and gets the tests, watches and warnings.)
Jun 27, 2011 | Midland WR-100 Weather/RDS Radio
How do you program your local weather county codes?
This radio doesn't have the facility to be programmed for your local weather county code.
When set to alert it will pickup on the strongest alert signal in your area.
May 05, 2011 | Eton Solarlink FR600 AMFMWeatherSW Radio
How do I set my Eton Fr400 to get weather alert? Does it need to be on a particular station? Should it be turned on?
Free PDF Manual at the link below detailing how to setup.
http://www.etoncorp.com/upload/contents/307/FR400_Manual_0107.pdf
Please post State, County & ZIP is you need any assistance with your weather station frequency.
Please leave feedback.
Cheers
Andy
Apr 28, 2011 | Eton FR400 Radio
What does "check OP" mean
This means that the weather radio has not received the weekly test signals for over a week. Turn the radio off and then back on. Next set the radio to announce the current weather (on my unit the button is marked Weather) and listen to the broadcast. If you do not hear the broadcast, move the radio until you do.
If you can't get a good signal, check the NOAA site for your coverage area to see if the local emergency alert broadcast towers are under repair. If needed try one of the other towers that cover your county. Sometimes you may get one location better than the others if you are near the edge of the county or are surrounded by hills. http://www.weather.gov/nwr/Maps/ has the maps by state and those link to the frequency of each tower that can be heard in a given county.
If the radio still fails to hear the test alerts, you may need an external antenna or a new radio. (Caution: the external antenna may hear a more distant tower and not give your local alert. We got the wrong state on one radio.)
(who has one weather radio on each side of the house set to two different towers. I live 2 miles from the state line. We had severe weather a few days ago and only the in-state tower broadcast the severe weather watch. The local television stations displayed different watches and warnings depending on which NOAA coverage area they checked.)
Apr 16, 2011 | Vacuums
Hi! I've been under 4 different tornado warnings today, and my weather radio hasnt given me one alert. I just put new batteries in it, and checked to make sure I'm on the right channel and the right...
Do you hear a broadcast when you hit the Weather/Snooze button? Is the transmitter that you have programmed broadcasting? NWS does have downtime at the various transmitters and these will be listed at weather.gov. (Click on the map for your region and look at the links in the News of the Day section.) If the signal is being broadcast, try changing where you have the radio placed until you hear the broadcast come through clearly. With one weather radio, I found that I had a better chance of getting the NWS alerts from a different tower than the one listed for my county. My location is closer to this other transmitter. See http://www.weather.gov/nwr/Maps/ for where the transmitters are located in various states. Click on your state for your local map. Check the map for adjacent states if you are near a state border.
Do you have an external antenna? Check that it is properly connected. If not, consider adding one positioned to get a better signal for the nearest transmitter to your location. (With an external antenna, we can get one of several transmitters on that weather radio. This means that we can easily switch when the best transmitter is down, as well.) See www.midlandradio.com to see the antenna that they recommend - which should be placed in a window. This is the 18-259W VHF Through-glass antenna.
Has your radio been picking up the weekly and monthly tests before this? These only give a text message not an alert tone with this Weather Radio. The alert will reset within 6 hours.
Did you set the alarm to Display alerts? This is the silent alarm mode - Tone or Voice would give an audible alert. Check this by pressing Menu then use the Up arrow until you see Alt Type. Press Select and use the Up arrow and then scroll through the options. Press Select to set your choice and then press Menu to exit the menu. Check the volume setting if you have the alarm set for tone or voice.
I hope one of these items help. Otherwise, contact Midland for support. They charge $45 to fix out of warranty weather radios plus a $7.50 shipping and handling charge for any repair. The S&H charge is not required in all states. http://www.midlandradio.com/Resource_/OwnerManual/122/WR-100B.pdf is the direct link to the manual and has the Service details. The direct link to the pdf may not work; you can find this via Google or at the Midland site.
(btw, my household had one weather radio that continuously would lose the ability to hear the test alerts even when placed in a spot that usually got the best reception for the unit. Since that one also did not respond to S.A.M.E. codes properly, we replaced it and put it in our workshop where the intermittent signal loss wouldn't always be critical. Without an external antenna, positioning the radio for best signal took walking around the house many times. Even with the external antenna, it took a while to find the best placement for the antenna.)
Oct 26, 2010 | Midland WR-100 Weather/RDS Radio
Radio does not alert
set it for county code 99999. make sure you can hear the station when you press the WEATHER button. You should see NOAA in the display window. The radio is tested every Wednesday between 11am and 12 noon and you should have a TEST message every Wednesday if it is working. You can set it for Display only, Voice or Siren, so check your menu settings, okay?
Aug 20, 2009 | Midland WR-100 Weather/RDS Radio
I've lost the operating manual for my Eton FR-300 emergency radio
Your radio does not offer the S.A.M.E. capability that would let you receive alerts for just your specific area, but it will let you receive all alerts broadcast by the NOAA station that your radio is tuned to. Here is a link to the owners manual where you can find more details:
http://www.etoncorp.com/upload/contents/307/U070165_FR300_Manual_US_053107_low.pdf
Bill B.
San Antonio
Mar 28, 2009 | Eton FR300 AM/FM/Weather/TV Radio
Program county weather code
Bill B.
San Antonio
Mar 28, 2009 | Eton FR400 Radio
Not receiving alerts anymore...
My wr-100 came with a special note inserted with the instructions that the WR-100 was programmed to not give off an audible alert on tests. This is to supposedly protect you from thinking you have a real emergency. Mine is new. Maybe the older ones had an audible test alert. I assume yours gave an alert at one time??
Feb 06, 2007 | Midland WR-100 Weather/RDS Radio
Eton Solarlink FR600 AMFMWeatherSW Radio Logo
48 people viewed this question
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
RobertFonner
RobertFonner
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
