Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No power after 1 min intial plug in
Have replaced bad caps-i plug in unit green light flashes for 1 min. then goes out none of the buttons on frent do anything---allso the light fan is not running when green light is flashing --any ideas
thanks willy, email at w55bb42@gmail.com
  • 4 more comments
  • wewilly Oct 30, 2008
    have allready replaced power board whats next thanks w55bb
  • wewilly Oct 31, 2008
    i have replaced power board and replaced bad caps on dm board and caps on signal board
    whats next thanks
    wewilly
  • wewilly Nov 05, 2008
    whats next thanks
    wewilly
    yes i have
  • wewilly Nov 06, 2008
    resisters seem ok ---on power board with pluged in on tabs i have tps 12 have 12.2 on tp -15 have -16.9 on tp +15 have +16.9 on tp 30 have 30.93 on tp 12 have .019 on tp 3.3 have -.008 on tp 5 have
    .838 hope this helps thanks wewilly
  • wewilly Nov 07, 2008
    thank you ---is there something on one of the other boards that activate the 12v on tp 12v
    thanks wewilly
    Guru:
  • 558 Answers
Have you check out the Transistors in the Circuit, since most of bad transistors will causing problems as mentioned by you..
Incomplete circuit with faulty transistors, necessary to be replaced.
Posted on Nov 06, 2008
  • Puneet Jain
    Puneet Jain Nov 06, 2008
    After then, check out the Coils present on the Circuit board, on DM board and signal board panel. And if necessary replaced the faulty one.
    Sergeant:
    Novelist:
  • 196 Answers
Something is definately short on your main board thats why the tv is not working. so check 1 by 1 from the short tracks,any burnt or bulged up capacitors,any ICs shorted out or burned from top,also check the tiny fuse on the main board if that fuse is blown out the tv will not become ON.if everything looks perfect.then check are these all electrical component connected to the board properly or any of them is loose.check out whole board.do dry/cold  solder to the main board let it dry for some period of time as the soldering joints holds the board properly and firmly.also check the power wire of the tv which goes in to the electric outlet if that is cut somewhere or not connected properly.as the power comes  but the picture will not come as the required current is not given to the tv.
thanks.
  • 728 Answers
You might have a short somewhere else causing the tv togo into auto shutdown mode which protects it from catching on fire. You will need to get this checked by a professional and they should tell you the problem and they should be able to fix it for you.
Posted on Nov 05, 2008
  • 2,071 Answers
Try also to check all the resistor there maybe there is an open or change value causing the voltaged trapped.
Hope may it help;
Regards;
VOTIT
  • LORETO LACARON
    LORETO LACARON Nov 07, 2008
    Yes, Mitsubishi can be very good about compensation on problems that are repetitieve and catastrophic. You need to be communicating with consumer relations and you need to be diligent and patient. My experienceis that in the end, Mits takes care of their customers better than most, even if the process is clumsy and at times very frustrating.
    This can be a more complicated problem than just changing the DM. There areseveral things going on in this chassis that we have not yet figured out. I just had one of this model that we did the following on:
    Changed the bulging caps on the DM.
    Changed the DM per Mitsubishi instructions.
    Changed the EEPROM.
    Changed the bulging caps on 4 boards in the set.
    Changed the reset ICs
    Changed the Signal Board.
    After none of this worked the soloution was to replace the entire chassis,which came in defective with a bad EEPROM. Mitsubishi paid for the parts.
    Unfortunately, Mits is not supporting component level repair on these boardsand we have only limited block diagrams for some circuits, not complete schematics. This means that we are not able to figure out exactly what is failing and troubleshoot the sets very effectively. Additionally, they don't have enough of the boards and the chassis is on backorder. They won't tell us what they are doing to fix them, so we are largely stuck waiting for expensive parts like an entire chassis. Mits is eating parts and in some cases labor when we could be field repairing them much more effectively if we just had schemaitcs and some info. Stupid, short-sighted policies, IMO.
    Keep calling customer relations, get file numbers, get tech log numbers from your servicer for any communication they have with Tech Support at Mitsubishi,get everyone's name that you talk to and keep good notes. Like I said, with patience and diligence, you can likely get some accomodation from Mitsubishi.How long the fix will last is uncertain.
    Also, be sure that you are using the coaxial line protection on your surge protector, and be sure that your in coming lines are grounded according to electrical codes.
    Re: Mitsubishi WD-52825 Blinking Status Light:
    The first thing to do is a system reset using the recessed button on the front panel.
    >>If that does not work, unplug the set and let it sit overnight.
    >>If it still does not come up .Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, holddown the Device and Menu buttons together for about 5 seconds.
    The Power light will start to flash in a two digit sequence.
    For example, 3 flashes, then 7 flashes = 37.
    Here are the error codes, and the corresponding problem:
    12 = No error detected, check power supply.
    32 = Lamp Cover is open.
    33 = Air filter cover is open.
    34 = Lamp abnormality
    36 = Light Engine (DMD or Lamp Fan stopped)
    37 = Exhaust or Lamp Ballast Fan stopped
    38 = Lamp Temperature High
    39 = DMD Temperature High
    41 = Short is detected
    44 = DVI cable between FMT and Engine disconnected
    IMAGES
    Regards;
    VOTIT
    President:
  • 2,712 Answers
Have you checked for broken solders? Proper connections, etc?
Posted on Oct 30, 2008
  • Mitsubishi Master
  • 19,396 Answers
If you replaced power board capacitors check that they haven't blown again, in this case replace board.
    Top Expert:
  • Mitsubishi Master
  • 77,544 Answers
I did all this to my big screen, result the whole system was out of align, the cost started to exceed the value of the TV, bought a new LCD and have been happy ever since.
I have a mitsubishi 62" wd62525, I replaced all
When you unplug the set it then when powered up waits for the DM unit to boot up----the green light blinks on the front for about 70 seconds and when it goes out the set can be turned on.
If this is the case I have a suggestion, let me know if I have described the situation correctly.
SD TECH
Oct 25, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Infocus Lp530 that as soon as you plug it in, all the lights on the top will continually flash green and an audible clicking sound can be heard. These two things occur before the power button is...
You can try removing the main board & reseating it. Also try plugging into another outlet & make sure the plug has a ground prong on it. Itshould have 2 flat & 1 pin shaped prongs. Otherwise the clicking sound may be the lamp trying to ignite. Normally when you plug in the LP530 the green power light is on steady & then you press it to start the lamp. If its flashing as soon as you plug it in it's likely that the main board is bad, the button board is bad, or the ballast/power board is bad.
You should remove the lamp & inspect it. It should be clear without bulging in the little bulb behind the lamp glass. I service LP530s all the time & something like that is usually the main board.
Good luck,
Jim
Apr 15, 2011 | InFocus LP530V Video Projector 2000 ANSI...
Power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
Aug 04, 2009 | Sanyo PLC-XU47 LCD Projector
Tv will not turn on
Common problem with this set are the two 1000uF@25v capacitors and the 150uF@400v cap on the power supply board.
May 12, 2009 | Apex Digital LD1919 19 in. LCD TV
Magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Jan 29, 2009 | Philips 32MF231D Television
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Blinking green timer light
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
TV will not switch on, green light flashes for 30 seconds but it still does not come on.
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Dec 14, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
