Question about Brother HL 1250 Laser Printer
Brother Hl 1250 Laser Printer
The red alarm button stays on constantly and I cannot print. I have changed the paper, and the toner but it still does not work. I believe there is a problem with the paper pickup. Even when I hand feed it one sheet of paper it still will not work and the red light stays on.
  • Arnaud Ledun
    Arnaud Ledun Nov 26, 2008
    Drum light is solid yellow and Alarm light is red blinking 15 times and repeat...
JohnSc
  • 21 Answers
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Posted on Feb 11, 2008
SOURCE: I believe there is a
I knew I had to take out the toner cartridge but I couldn't remember if it was one piece or two. I went to over a dozen websites before I found some details beyond "Take out the cartridge." However the image was not clear. I asked for help from my wife, who knows less aobut computers than I do. She said, "It's definitely two pieces," and took the toner cartridge out, whereupon I removed the paper stuck in there and put the toner cartridge back in. Moral of the story: When even the instructions fail, ask you wife. Thank you, dear!
Posted on May 26, 2008
rscheutz
  • 54 Answers
SOURCE: won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Posted on Mar 25, 2009
SOURCE: HL-5140 Brother laser printer red status light remains on.
Help me, please . Red status light on. PC recognises printer. Nothing happening. Toner was on for a few weeks. But now new toner cartridge and still solid red light. What is this?
Posted on Apr 29, 2009
SOURCE: Brother HL 1250 Laser Printer Alarm light blinks
I have saeen this happen and there is usually a paper jam somewhere in the machine. Remember, it doesn't take much of a piece of paper to jam. Use a flashlight and look inside your printer closely. Also check your toner supply level.
Posted on Oct 22, 2011
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Brother HL 1250 Laser Printer Alarm light blinks at same time as ready light and printer does not print - why?
Oct 02, 2010 | Brother HL 1250 Laser Printer
I replaced the toner cartridge, but I am getting a blinking green ready light with a blinking red alarm light. will not print.
This is a paper jam error. Try reloading the paer if you can not find any paper stuck inside the printer. Then press the start button.
Dec 09, 2009 | Brother HL 1440 Laser Printer
Printed paper is stalling within the output.
That's a common problem on that machine, those rollers at the exit get coated with toner and fuser oil, so they have no grip to pull the paper thru. If you dampen a rag with alcohol and power off the printer, each time you turn it on or close the front door the rollers turn and you hold the damp rag against the exit rollers one at a time to clean them...
Nov 13, 2009 | Brother HL 1250 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
Brother HL 1250 Laser Printer Logo
131 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
