Question about Samsung 226BW Monitor
Samsung 2232bw monitor
The monitor turns on but after a few minutes it flashes:
Not Optinum Mode
Recommended Mode
1680X1050 60hz
Why does it do this and how do I fix the problem. The monitor has worked fine up until now.
  • 849 Answers
This shows the internal circut problem, need to consult a technician
Posted on Nov 07, 2008
Have a Samsung SyncMaster 2232bw monitor that the power button flash is there a reset button on this monitor
I have another model of Samsung Syncmater monitors.
According to the manual, press the Source button then a key on the keyboard.
According to try pressing Source and Power or Power and Auto button at the same time.
Per, if these things don't work then the monitor needs an electronic repair(detailed in forum) or, if you are unable to get it fixed, replacement.
Please check for additional information.
Mar 24, 2016 | Samsung Computers & Internet
Samsung SyncMaster 710v isnt responding, keeps
Hello , this is very common problem with this model .
The problem is with main board there are two solutions:
1.Replace the main board with proper part
2.The trick you can try is to add resistor 47ohm on main board chip between two pins.
If you are not familiar with electronics do not attempt to repair it by self , go to proper service center. There is always possibility of electrolyte-shock, or high voltage shock . Hope this helps.
Fix Samsung SyncMaster 710v Not Optimum Mode Recommended Mode 1280 1024 60...
Oct 12, 2014 | Computers & Internet
I have Syncmaster 2232bw. When I first switch it on it flashes for about 1 minute before it stopsa flashing. After that it runs fine until I switch off and it cools. Is this the backlight dying?
This happened with my 2232bw also. The problem was that the 5 820uF capacitors that had burnt out so I replaced them with 5 1000uF capacitors and it's now working like a dream.
Hope This Helps
Oct 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Jul 05, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor is going out...
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
Reparaturhandbuch für Samsung 710n,913v,510n und andere
Jul 01, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
Jun 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
2232bw samsung DVI in problem
Try a DVI-D (Digital) Only cable, without the analog (right section). I´m basically talking about a DVI-D to DVI-D cable.
Jun 08, 2008 | Samsung 226BW Monitor
Not optimum mode recommended mode 1024 x 768 60hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Samsung 710N
hi, try with another crt monitor to check if the display card is ok..if that works fine then u will have to take it to the service center.. let me know..
Jan 10, 2008 | Samsung 710N V2 17" LCD Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
626 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
