Question about Waring Primo Pasta - Pasta & Dough Maker
Die holder the front of my die holder broke of, now there is nothing o hold the die in place
My sim card holder broke how do I fix it so sim card will stay in
Hello, If the sims card holder broke you will have to either call cust support for the phone and talk to them or take to a phone repair place for repair.
Oct 21, 2015 | Cell Phones
My van starts up then dies there is fluids leaking in 2 places at the front part of the engine also. How can I fix this problem?
better call a mechanic fluid leaks could mean soft plugs if motor froze or it could be cracked block .
Apr 05, 2015 | Worldwide 1998 Dodge Caravan 3.3L...
2005 pontiac G6 starter won't work. New battery
Are you talking about the car battery? or the remote battery?
Aug 14, 2011 | 2005 Pontiac G6
How do I fix the door/lock of my 1991 Acura Integra? I can only open the driver side door from the outside
There are only 2 places that you have the problem on the inside door handle. one is at the handle,and the little plastic holder that holds the rod to the handle broke, or the plastic clip the the door lock mechanism broke. the first can be removed without taking the door apart. the inside door handle has a screw holding it in place. you can remove the handle and see if its broken. the second requires you to remove the door panel, to replace the clip that hold the rod to the lock. I door handle in the car is a dealer item only(sorry to tell you that), the clip for the lock, you can get at the auto parts store. hope this helps
Jan 11, 2011 | 1991 Acura Integra Hatchback
I have a GE Quiet Power 3 that has completly died. I cannot get a light to come on or anything to beep when pressing buttons. I checked the circuit breaker and outlet and they are both working fine. I...
A dead set simply means a cut off of power supply. Open the back cover of your dishwasher . Locate the area where the AC cord is located and look for the plastic fuse holder which is usually installed in one of the AC cord line open it and replace the fuse inside with the same amperage or value.
Nov 22, 2010 | Dishwashers
The ink cartridge holder plastic lock broke where the top of the holder clicks into the bottom to hold the ink cartridge in place. what can i do to fix it.. tape doesn't hold
If you have the quick fix --
S
elleys Quick Fix GelFast setting ethyl cyanoacrylate (supa glue) based adhesive with a non-drip gel consistency which dries clear.
What materials is this product suitable for?
  • Bonds a variety of porous and non-porous surfaces
  • Metals
  • Wood
  • China
  • Rubber
  • Leather (test first as some leather may become hardened or discoloured)
  • Some plastics
I or have to purchase the part
Jan 04, 2010 | Lexmark X1150 All-In-One InkJet Printer
I hit a bolt and broke the blades. OK, I now have new blades. But I also broke the blade holders (chipped them where they also hit the bolt). I cannot find the part or its name. Blade holder? Just a...
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00701v-1.pdf
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00066v-1.pdf
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1594K
The above three links will lead you to the Bosch web site, the 1594K manual which will describe the blade arrangements, and to the parts diagram that has the parts listed and their part numbers.
Hope this is of some help!
Aug 12, 2009 | Bosch 1594K 3 1/4" X 3/32" Planer Kit with...
Replacing the sand paper
Ok on the front and rear of the sander you will see metal wire holders. These extend each side of the sander and form a loop to which you can release them from their holder. Release each side ring and then that will lift the wire holders up at the front and back of the sander. This releases the sandpaper sheet. Now cut or add a new sheet that is long enough to fit over the sander base and fold up under the wire holders. Then clip the rings from the wire holder back in place while holding the sandpaper under the wire holder to hold the sandpaper in... same process for each holder (one front and back). That's it!
Jun 13, 2009 | Black & Decker QS800 2.0 Amp 1/4 Sheet...
Hoover Floormate wheel assembly
You must remove the top gray piece it has six tabs 2 in front, two in back and 2 on sides where the foot pedals are. Be very careful not to break them. Then you cn remove screwsa nd install the piece.
Oct 22, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Waring Primo Pasta - Pasta & Dough Maker Logo
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
