Question about Panasonic Lumix DMC-LZ7 Digital Camera
The lens cover on my Lumix TZ7 will not open correctly
The lens springs fully closed when powered down but on power up it will only flop open when shaken or if pushed open with fingers. the lens functions normally & lacks pictures fine but upper lens cover will flop partially closed.
SOURCE: lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Posted on Dec 19, 2007
SOURCE: Panasonic lumix dmc-lz7 lens cover won't open
Hey how you doin.
I had the same problem during a trip around Australia, some bull dust built up around the lens area. The only thing I did to rectify the problem was to blow it out with a tyre inflator at a road house when I stopped for petrol. No problem since then.
You may have some fine sand wedged in the cover area aswel.
Good luck 'R'
Posted on Feb 04, 2009
  • 247 Answers
SOURCE: I want a manual of panasonic lumix DMC-TZ7 in
This is the ZS3 in North America. Find it from this page http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZS3S The manual is at http://service.us.panasonic.com/OPERMANPDF/DMCZS1.PDF
Posted on Dec 13, 2009
lock123
  • 6831 Answers
SOURCE: I have Panasonic Lumix DMC-TZ7
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 10, 2010
ZJLimited
  • 17970 Answers
SOURCE: When I turn the camera
Your previous diagnostic definitely indicates a mechanical problem. It is very likely that there is a blockage or a broken internal part that is preventing the correct positioning of the lens which triggers the shutdown and error display. You can try some of the procedures listed below to fix it yourself. These simple steps have helped many people restore their cameras to functionality.
Before trying any of the suggestions, make sure your Camera has new or fully charged batteries and it is in recording mode. Try compressed air. With a fine tip can of dry compressed air (not a blow dryer) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It could possibly remove all dust and sand. Turn the camera on and it should function fine.
The links below give additional step by step DIY instructions on troubleshooting and attempting to fix this problem. A Canon camera is used to demonstrate these procedures but, the lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time. Click on or copy and paste the links into your browser. Pay special attention to the opening statement at the first link if there is any chance of warranty repair.
Check this links for additional details that could find in this article link: fixing-lens-error-on-digital-camera.html
Additionally, here is a video of the normal power up sequence of the camera and there other moethods:
1. Here is the first alternate method
2. Here is the second alternate method
Keep us updated.
Posted on Jun 08, 2011
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
The lens cap of my lumix TZ7 no longer opens. thank you for the solution.
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Aug 13, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
I have the tz7 and have 2 problems with this. when turning on or off the lens cover takes ages to open or close sometimes you have to help it and use your finger to open it!the other is when operating the...
It is normal these things. You can switch it off and then charge it fully and then you can see whether the problems is still there. If this does not help then you have to go to someone who repairs camera.Do not forget to vote for me it is very important
Sep 13, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I have Panasonic Lumix DMC-TZ7 Digital Camera. i have been using camera since 10 months. now i have problem in zoom'er. it is not working correctly. seems like spring action is not correct, it gets struck...
Hello
Regards
Andrea
Sep 10, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens cover stuck open
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 19, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Panasonic Lumix DMC-LZ7 Digital Camera Logo
212 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
