Question about Sony Computers & Internet
My Sloney E reader doesn't seem to be taking a
    Novelist:
  • 206 Answers
Because the battery is not removable? Best thing is to allow the E Reader to be completely cleared of any charge. OR While it is plugged in, press and hold the power and N buttons simultaneously for 20 seconds. I then turned the device on normally. Hope this help, have a great day..
Posted on May 13, 2014
2 Suggested Answers
martin-r
  • 151 Answers
SOURCE: Charging Light is on when battery in , and charger
This sounds like a USB problem. If there is a short or damage within the port the computor will detect it and prevent it from starting. Usually it's a USB port you always use. This may help, Plug in the mains charger and remove all USB devices. This will confirm weather its the computer or a USB cable/device. If the computer still doesn't start, get a bright light and a magnifying glass and look inside all the USB ports on the computer. In the middle of the port there is a flat plastic piece with 4 metal contacts attached to it. Check to see if they are bent, twisted or flattened in any way and with a pin or other suitable pointy device, attempt to straighten any damaged contacts. If you cannot get the contacts aligned, just try to get them away from each other and away from the wall of the port, then insert a piece of card or folded paper above and below the contact strip and tape them down. This will insulate the port and stop a reoccurance of the problem. You should find the computer starts (with a few complaints from windows) normally. this has worked for me 9 times out of 10 for this problem.
Good luck.
Posted on Apr 05, 2011
I have htc windows 8x phone. My phone wont charge! i plug it in and the red charging battery icon doesn't appears, but it wont turn on no matter how long i charge it. i just got my phone 5 days ag
I think you have damaged your charging pin in the phone by mistake either by dropping the phone or while taking the cord out or inserting. I think the best way to get this fixed will be to go show it to the store that you bought it from/microsoft store. Hope this helps. All the best.
Mar 11, 2013 | HTC Windows Phone 8X
THEY ARE PLUGGED INTO MY LAPTOP AND THEY WONT CHARGE.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 08, 2012 | Sony Reader Pocket PRS-300
My ereader isn't charging properly
First Option:
Second Option:
Aug 05, 2012 | Sony Reader Touch PRS-600
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
What if I can't seem to get the photos off my
Recommend that you use a CF card reader instead of trying to download directly from the camera. It'll save you aggravation in the long run (it's much faster, reliable, and doesn't use your camera's batteries). Here's one I highly recommend. But if that is too costly, they can also be very inexpensive (as seen here). You remove the CF card from your camera, and insert it into the reader. Then just plug the reader into a USB port on your computer. Your card shows up as a drive, that you can just copy and paste the pictures onto your hard drive.
Sep 11, 2011 | Canon PowerShot S200 / IXUS 178 Digital...
My Sony ereader touch isn't charging. Pluging it in to either the computer or the wall charger, and the light doesn't go on. The screen is frozen on the last page it turned to.
Hi suebagnall,
If the redlight does not come on, try the following:
1. Connect the reader to the wall charger (make sure you use the Sony Charger ACS5220)
2. Hit the Reset button at the bottom of the reader
3. Check if the redlight comes on
4. If so, leave the reader charging for 15 minutes to see if it takes the charge
5. If this does not resolve the problem, probably you will need to contact Sony to get it repaired
eBookBoy
www.digitalreader.freeforums.org
Jun 27, 2011 | Sony Reader Touch PRS-600
The boyfriend's reader has stuck on the title page of a book. Everything I've looked up says to do a hard reset, but the first step is to power the reader off. His won't power off. I've...
Hi Zoetic,
Looks like a charging issue, tryh the following:
1. Connect the Reader to the computer
2. Hit the Reset at the bottom for 3 seconds
3. Make sure a redlight comes on at the top of the unit
4. Leave the reader charging for about 15 minutes or half an hour
5. Disconnect the reader and check if its functional now
6. If not try the reset again
eBookBoy
Jun 19, 2011 | Sony Reader Touch PRS-600
Don't have a manual. Charging in electrical outlet at home and don;t know how long to charge for. Plug in shows a red and green lite, both on and I have been charging for over 4 hours. Comments
Most garmin nuvi satnavs take 4 hours to charge with a mains charger or a car charger. It takes 8 hours with a computer. There's a batter indicator on the screen that shows WHERE TO and VIEW MAP. It will probably only appear when the charger is disconnected if it's the same as other garmin nuvis.
You can get the manual in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi680_OwnersManual.pdf
Jun 14, 2011 | Garmin Nuvi 680 GPS Receiver
I'm trying to authorize my Brand New Sony 650 reader at the Reader Store. When I connect my USB cord to the computer the only thing appearing on the screen of my Reader is "Charging Battery"...
you have to download the software so it reads everything of the phone if the phone came with a cd thats the software try installing it and it will work
Mar 16, 2011 | Sony PRS650
Computers & Internet Logo
182 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
