Question about Whirlpool Washing Machines
LHW00050PQ wirpool washer mashine LHW0050PQ do not pumping water from mashine into drain. Whot happend?
  • 1294 Answers
SOURCE: whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Posted on Apr 25, 2007
JULIANFIX
  • 975 Answers
SOURCE: clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Posted on Apr 16, 2008
  • 5 Answers
SOURCE: Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
Posted on Mar 05, 2009
  • 27 Answers
SOURCE: The mashine does not pump the water.
pump may b nakerd or fiter trap may b blockd
Posted on Oct 04, 2009
  • 10865 Answers
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
Posted on Mar 08, 2010
How do I access the water pump to change it
Under the drum (front door) is usually a panel that comes off. IT is the whole bottom of the front of the machine. Then you can see the drain and the pump. The drain should have a large cap on it that you can remove. There is most likely a piece of clothing or something in the drain. Get ready for water to come out when you take the cap off the drain.
Aug 19, 2013 | Whirlpool LHW0050PQ Front Load Washer
The washing machine won't drain water? how can I fix it? Its seems clogged with debris
Ideally you need to remove the pump and outflow pipes and flush them out. Also check the pipe between the drum and pump for a blockage. Back flush the outlet pipe from your hot water tap..
Jan 28, 2011 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool front load washer (model #LHW0050PQ4) will not drain the water or spin. What parts do I need to look at.
look at the drain pump. to remove nay water in the machine use a wet dry shop vac,attach it to the end of the drain hose.then remove the hoses from the drain pump and look fro any obstructions.if you do not find any thing then you may need to replace the drain pump or door lock mech,
Nov 03, 2010 | Whirlpool LHW0050PQ Front Load Washer
It quit in the middle of the cycle with a code f 21
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank You
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
What is code F21
F21 is:
LONG DRAIN
NOTES:
Press PAUSE/CANCEL two times to clear the display.
kinked.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
From time to time the mashine is not evacuate the water and the mashine will not start for a new load .I have to unscrew the filter,drain the water and then will wash. Is a problem with the pump? thank you...
a front loader huh, usually there is an access panel at the bottom front held on with 2 screws. remove this panel and trhere should be a trap filter that is plugged up. remove filter and clean it out, than put it back. or the water pump is going bad try the filter first.
Nov 07, 2009 | Whirlpool LHW0050PQ Front Load Washer
Small front loading maytag lhw0050pq needs minor adjustment
These Maytags are a little challenging - Remove the rear access panel and look for the water pump device attached to your drain hose.
Remove this unit and clean debrees in it, that is the main cause for these units to stop during the middle of the cycle.
Aug 18, 2009 | Whirlpool LHW0050PQ Front Load Washer
Feb 19, 2009 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
