Question about Panasonic VIERA TH-37PX80B 37 in. Plasma TV
Blown fuse panasonic th-37px80ba
A fuse has blown and now tv wont turn but just get blinking red light
djchillsnyc
  • 151 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
  • 10 Answers
SOURCE: TH-42PX60U red light blinks 10 times wont come on
Well the problem was solved with a simple kit i found online
there was a open 10ohm resistor and a shorted transistor. Q406- transistor and the R410 resistor take a dvm and test them on your psu. if you have decent soldering skills im sure you can repair your tv your self for well under $40.
Posted on Mar 05, 2010
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
Jan 29, 2013 | Panasonic TH-C42HD18 42 in. Plasma TV
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
50 inch Panisonic TH-50PZ85U, wont turn on and has red light flashing 10 times
thats usually caused by a blown thermal fuse on the transformer and the 10 blinks appears. I can assist but will need to do it via email you can contact me at slinteriors@yahoo.com
Mar 19, 2012 | Panasonic TH Televison & Video
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
PANASONIC TH-42PZ700U - WILL NOT POWER UP
THIS SYMTOM MEANS THERES A POWER PROBLEM DEPENDING ON HOW MANY BLINKS WILL TELL YOU WHAT BOARD OR PANEL IS BAD OR NEEDS TO BE CHECKED IT MAY BE A BLOWN FUSE
COUNT THE TIMES IT BLINKs and i can tell you what internal circut board is bad..
Oct 11, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic VIERA TH-37PX80B 37 in. Plasma TV Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
