Question about iRiver H10 MP3 Player
Player freezes and wont record line in
The player has been good for about 4 months, but now it wont play some of the saved files, only the recorded ones. i also cant record any line in stuff. yes i do have the cradle and now when you finish recording it freezes up and wont save anything. i think it may need to be re formated?
  • 8,596 Answers
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jun 26, 2008
SOURCE:
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
How to record from Casset tape to CD disk? Thank you !
You can do this with your PC. Download a program called Audacity. It's free. With it, you can record audio from your Line IN connector. You'll need to connect your cassette player to the Line in on your PC. Start Audacity, set it to record and play your tape.
If you want to save the files as a .mp3, you'll also need to download the LAME mp3 encoder. In any case, when you have the file recorded, export it as a .mp3 or .wav and then use your CD burning program to create the CD.
Nov 06, 2009 | Durabrand CD-2086 Personal CD/MP3 Player
I want to put my LPs to an external hard drive, what do i have to do?
Plug your turn table into your input sound card (line in on your sound card) Use a program like Nero Media Player, or any digital recording program ( Sound Blaster or Wave Studio) Tell it to save the file as mp3, that simple. If you are an experienced Computer user and have a Wave Recording program such as Audacity [free] or Adobe Audition [$$$] you can do this: 1. Your record player must have a LINE OUT.....usually go from your stereo receiver [You can get turntables with internal Line outputs...this is what I have...via ebay] 2. Output from Receiver [turntable] must be the small [headphone like plug...used to be called Sony Plug...now it's the 3/32nd I believe.... 3. plug this into the line in of the sound card....it's the arrow that points INTO the little hole. Now the sound card can read the signal.....but wait...! 4. You must enable the little box in the sound card properties called "Line IN"....put the check mark there. 5. How to get to the Properties? Bottom right of screen there should be a speaker ICON....double click that. Then go to File....Properties....record.....then look for the LINE IN....check it. If you don't see it. Then you have to ask someone in person to help you. 6. If you get it working. Great! 7 Now open a recording program and press record....then play the record. You should see a wave file going across the screen. Then save it as an MP3 file. 8. Advanced tip: if you record at a rate of 59594 instead of 44100 then you can play the 33 1/3 speed at 45 RPM and save about 30% time in recording from a record. Then convert back to 44100 and it will be normal speed. I do this on ALL my LP to MP3 recordings... The above is for more advance type computer users.
Sep 02, 2009 | Roxio Easy VHS to DVD for PC
Samsung R150 DVD recorder system error and freezing.
go to menu, select formate, formate disk in V mode not VR.when finished recording finalize disk. you can then play on any dvd player.
Jul 10, 2009 | Televison & Video
My Sansa stopped playing videos and voice recording
You should not reformat the player unless you want to clear the mp3 player completely - erasing all music, recording, and other files completely.
Once you are done recording, the Sansa takes time trying to save the recorded files - it appears that it is freezing, but give it some time - it is just "thinking."
If the recorded files suddenly disappear, it is because the Sansa player has two modes - MSC mode and MTP mode. Files that appear in MTP mode will not appear in MSC mode and vice versa. If the recordings do not show up, go into your settings menu and switch the USB Mode.
-THa Mp3 Doctor
Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
Intructions for recording Mic or Line In and SAVING to PC
Hi
Recording is quite easy:
1. To record from the Mic, simply press the button on the side of the player with the red dot and speak into the mic - its the small hole at the top left of the player.
2. To record line-in: connect the small mini stereo jack to the player and the other end to the line or headphone output of a recording device. Use the menu to find 'line in recording' (its towards the bottom of the menu). Monitor the input signal and adjust its level using the VU meters on the V Plus. Using the volume control on your player device, ensure that the signal is not too loud so that it clips, nor too soft (it will be noisy). When ready, press the red dot button. Press it again to stop recording.
3. To find the recordings and transfer files to PC: using the Zen Explorer, find the folder 'Recordings' on the Zen. Your recordings will be stored there with file names such as "Line In {date, time}.wma". Simply copy and paste these files onto your PC and play them with Winamp or Windows Media Player. Note that they are in WMA format, not MP3 format, but that this is a better standard than MP3 and can be played on most MP3 players.
Hope this has helped, and now can someone help me - my Zen V Plus screen is dead, and I didnt' even drop it.
John
Jan 11, 2009 | Creative Labs ZEN V Plus MP3 Player
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
IHP120 20gb multicodecjukebox-voice recording
Sir,
I solved the problem .Actually under the SOURCE title it was under the LINE IN.There were some more options like INT.MIKE, EXT.MIKE, OPTICAL. So i first tried under external mike by connecting to the EXT.mike and selected the source and by removing the external mike switched to Int. mike and changed the source. It automatically picked according to the source and played the recording and saved it in the file and later heard the lecture with the head phone and later converted in to a file in the laptop. Now it is working nicely. A really a good product to make use and it is very much user friendly.
Thanks again.
regards
crsrinivasan
Aug 02, 2008 | iRiver iHP-120 MP3 Player
Photos I burn on computer jpeg image dont play on philips recorder dvdr recorder jmsdwnhm@tiscali.co.uk
alot of DVD players wont play jpeg files try saving the pics as a gif or other type of file to see if the DVD player will play them
Apr 07, 2008 | Televison & Video
Line in
You need a device that does not come supplied with the player.
Making LINE-IN recordings
Line-in recordings are used to record music tracks in digital format directly from an external player.
1. Connect an external player (like a portable CD player or a stereo system) to your player via the docking
cradle. (this is an optional accessory which is not supplied with your player)
2. Insert one end of the audio cable to the line-out connection on the cradle and the other end to the device
you want to record from.
3. Go to the main menu of your player and select Recordings > Start LINE-IN recording.
4. A message Connect line-in will be displayed.
5. Press 2 to start line-in recording, at the same time, start the playback on the device you want to record from.
6. Press 1 to stop recording.
7. Your line-in recording will be saved on your player as a PCM file (.wav extension). You can find this file
under Recordings > Recordings library > Line-in recordings.
-Tha Mp3 Doctor
Aug 17, 2007 | Philips GoGear HDD6330 MP3 Player
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
