Question about Belkin OmniView PRO3 USB PS2 16Port KVM Switch KVM switch 16 ports (S6620373)
Omniview PRO3 locks up - Belkin OmniView PRO3 USB PS2 16Port KVM Switch KVM switch 16 ports (S6620373)
Asrock 55 pro3 stuck at grey screen
If you are using PS2 Keyboard try USB type.
Jan 10, 2014 | Asrock A55 PRO3 ATX AMD Motherboard
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says adding video tee smart failed what will be the reason for this problems
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says cannot render video capture pin to null filter plz help me
Jun 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Pixel view pro3 tv tunner card it records but no sound
Try unmuting the linein this is a general issue for this type of tuner cards
Jul 29, 2009 | Prolink PixelView PlayTVpro Video Capture
I have a Viewsonic VS11531 27.5 inch monitor I use a OmniView® PRO3 16-Port USB & PS/2 KVM Switch. The monitor has a res of 1900 x 1200 but when I hook it to the kvm switch the display will not...
In the link below, on page 9 of the PDF the maximum stated resolution of the KVM is Up to 1920x1440 @ 75Hz.
http://cache-www.belkin.com/support/dl/p75457_f1da116z_man.pdf
The monitor supports up to 1920x1200 @ 60Hz.
It sounds like there is an issue of synchronization between the monitor and KVM. This will force the monitor into a lower resolution to sync them. You may want to check with Belkin to see if there is a firmware update for the KVM. There may also be a driver issue with one(all) of the video cards on the system. I recommend updating the drivers on all affected machines with the monitor connected directly to the individual machines. Rather than using generic drivers, I would use the drivers downloaded from the manufacturer of video cards and from Viewsonic for the monitor.
Jun 28, 2009 | Belkin Computers & Internet
KVM functionality
This happens on KVMs, some more than others. I have a couple of Avocents that work great with Dell and HP servers, a Belkin OmniView that works great with two Dells and OK with a home built. Bottom line is some switches work better than others just like some PCs seem to behave better than others. If you?re looking for suggestions I would stay away from the cheaper $50 and under switches unless you find a good, used, guaranteed one somewhere. I like the Belkin OmniView and Advocent (really expensive, meant for servers and other medium sized sites). I would stay away from LinkSys, they make good wireless equipment but haven?t heard much good about their KVM switches. The original post was a few months ago so this is really intended to help anyone in the future who is researching a similar problem and winds up here.
Apr 26, 2007 | Linksys ProConnect Compact KVM Switch...
Problem with Belkin OmniView KVM F1DS102P
Is the LED for position 1 and 2 always on? If the switch doesn't detect power on the PS2 keyboard connector it won't let you switch to to that position. If you are using a USB mouse with an adaptor or a wireless mouse try a conventional PS2. I have a MS wireless mouse one of my switches does not like and have to resort to that sometimes. Another issue could be excessive cable length or PS2 extension cables. Let us know if you have any more questions on this topic and please don?t forget to rate the post.
Aug 31, 2006 | Belkin OmniView¿ SOHO Series 2-Port...
Direct Access Buttons
the hotkeys are funcion becouse the ps/2 manual operation, but you have to claim the waranty fortunatily the omniview have 5 years in both parts and services claim it...good luck
Aug 10, 2006 | Belkin OmniView PRO2 8-port KVM Switch
Direct Access buttons
Belkin OmniView PRO3 USB PS2 16Port KVM Switch KVM switch 16 ports (S6620373) Logo
42 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
