Question about Sony Playstation 3 (PS3) Console
Ps3 is frozen - Sony Playstation 3 (PS3) Console
  • Eric Gordon
    Eric Gordon Feb 25, 2012
    When does it freeze at the main screen or after playing a game?
My PS3 froze while I was using the web browser I left it for an hour while I went out came home and it was still frozen. I tried to reboot by turning the power off and now all I get is a background screen
Your PS3 got some of hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such frozen problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
My screen is frozen in updates. It tells me to press ps button to use my controller. What is this?
Its the very middle button on your playstation remote. If its saying press the ps3 button on your control its possible your ps3 is not frozen but your ps3 remote has just turned off..
Press the very centre button and check the lights on the top of the joypad. Are any lights lit solid? Once the light comes on solid the controller is active. If these do not light youll need to charge your ps3 remote with the usb cable that came with the ps3.
Also if your ps3 remote is lit for number 2, hold down the ps button, very middle for about 5seconds. Should have an option for reassign controllers, select that and put your controller to number 1.
Hope this helps
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
My playstation is frozen dont want to work help
try turning it off then going into safe mode and restoring it to get to safe mode hold the power button on ps3 till you hear 3 beeps and it will turn off again then hold it again till u hear a double beep and thats safe mode try #2 and #4 on the safe mode screen
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
When I turn my PS3 on the screen is frozen... I can hear audio sound effects while I browse the menus but can't see what I'm doing. I can turn it off but when I turn it back on it's frozen on the same...
If your PS3 is freezing up then this happens in much the same way as the 3 red lights on the Xbox 360.
The GPU and the CPU heat up and you need to stop the heat to fix it.
You can send it in and pay $130 to get it fixed or you can use the recommended PS3 Repair guide that will have it fixed for you in under an hour!
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
My PS3 is frozen. I used the wireless connection
Wireless connection can be interferred with by bluetooths, wireless house phones. I'd try connected and see how that works.
i hope ive helped and i hope it works, let me know how it works!!
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
Ps3 frozen on the home screen
Google "Five Most Common PS3 Problems"
Check problem #3 for solution.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
PS3 screen frozen.
when the system is powered on hold the power button down until you hear it beep twice, I am unsure if this is what you were talking about or not but it should reset the system to factory settings
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 frozen
here is the # off the playstation site. hope this helps good luck with your ps3
Sony Computer Entertainment America
M-SAT 6:00 a.m. - 8:00 p.m. PST
Sunday 7:00 a.m. � 6:30 p.m
800-345-7669 (800-345-SONY)
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
System update 2.40
you know what happen bro the update f*ck up alota systems
Jul 04, 2008 | Sony Playstation 3 (PS3) Console
Ps3 online
Just a quickie but are you up to date with the PS3 software?
Not sure what the latest version is, your PS3 will normally notify you when it needs updating, it may be worth checking in the system update settings
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
