Question about Dell Computers & Internet
I changed my hard drive now it says I have no audio device
  • Oscar James Feb 25, 2012
    I have downloaded drivers from microsoft.intel, the mother board and the sound device website. Still no device3 found. If I put the old hard drive back in it works fine. I'm scratching my head!!!!!!
  • 62 Answers
Lost the driver download from manufact site and reload
Posted on Feb 25, 2012
How can I change the default language on NHDN-W55G car audio and GPS device to english?
Please help me to change to change japane language to english HDD DVD NHDN-W5
5G
Mar 16, 2016 | Toyota Genuine HDD Navigation NHDN-W56
Audio service refuses to start
The obvious, is it muted? NO. Disable device in Device Manager, enable device, no change, uninstall audio device, reboot, I don't know your OS, your OS should automaticly ID the audio an add driver. If it does not go to Acer website a download audio driver for your OS. Install manually. You stated,"after installing a hard drive I had from another laptop" . The Harddrive you installed, did you format it and install into this laptop and clone the drive? I am a bit confused by the statment, "after installing a hard drive I had from another laptop"?
Nov 07, 2012 | Acer Aspire One D257 Netbook
No audio device found
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope it helps
May 08, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Audio doesnt work from hard drive, speakers dont work when plugged in
The hard drive doesn't make the speakers work. However, the drivers that DO make the speakers work reside permanently on the hard drive...once you install them. To install the audio drivers for your computer, visit your computer manufacturer's site, go into the support section, enter your model number, download and install the audio driver, then restart the computer. Sound should be coming out of the speakers now, unless the speakers themselves are bad.
Mar 10, 2011 | Dell (76052) Hard Drive
Getting an error message 05 bad sectors detected
1.Your device or hard drive is needing replacement.
2. You may need to format and reload the data.
Bad sector errors are from usage on most mp3 devices.
Jan 06, 2010 | Argosy HV358T Audio/Video MP4/MP3/...
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
No audio outout device is installed
Did your vista install correctly? Is your computer got a 32 bit hard drive? This can happen if your computer worked fine before you changed to vista. or if it did not install properly or you put in a 32 bit for a 64 bit or vise versa. Check these out first. If computer worked before update this is most likely the problem or you may not have enough ram or hard drive memory for vista. Let me know i'll try to help you thru this.
Jul 02, 2009 | Dell Inspiron 1525 Notebook
Can't see Seagate external hard drive on Vista devices with remov
dougv52
If the drive is not showing up in My Computer but is showing in Device Manager then you most likely need to assign a drive let you the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 21, 2008 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Hi I have a WD1200BEVS hard drive making a musical two tone buzz. Any chance for repair?
If you can boot up your computer, I would back up your data before your hard drives fail completely. It is unusal to have both hard drives go at the same time.
Mere mortals such as me and you cannot repair hard drives, basically buy new ones to replace the faulty drives.
To reinstall Windows on your new hard drive, you will need the Windows XP or Vista CD install disk plus all the device drivers for all the installed devices in your computer (eg. video, audio, LAN etc.) and install those that Windows could not install.
Make sure when you download these device drivers that you select the ones that is specific to the version of the Windows operating system you installing.
Dec 06, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
