SOURCE: HP photosmart 7150 - looks like it's printing - pages blank
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: HP PSC 1610 All-in-One not printing anything including test page
try this.. i got the same problem before.. and the main problem is the NO MECH MODE.. try pressing the setup button then take the plug out of your printer.. (still pressing the setup button) and put the plug back.. and it will remove the no mech mode.. then you could print like before.. i hope this helps
SOURCE: HP Laserjet CP2025 stopped printing.
First thing to do is to turn off the HP. Clear out any print jobs that are sitting on your computer print que waiting to be printed. Turn the printer back on, wait about 1 minute then try printing again. If this does not work then clear the print job again and reboot your PC. Try printing again. If still you can not print then reply here with how the printer is connected to your PC. By USB cable? Ethernet? etc.
Thanks
Testimonial: "Great help!"
SOURCE: How to disable color printing on an hp cp2025
You can adjust the device settings under the driver properties.
1. Open your printer s and hardware folder
2. Right Click on the driver for the CP2025.
3. Vista/ Xp click on properties, Win 7 Printer Properties
4. Go to the Device Settings tab
5. Under installable options:
6. Change the device type to Monochrome and apply
7. If the printer is still printing in color select automatic configuration and select configure now
For more questions please write;
Al
[email protected]
