Question about Refrigerators
How do you remove the interior back panel in the freezer section of a Kelvinator TPK140EN?
whytfang
  • 170 Answers
SOURCE: freezer fan is making whirring noise
Generally the freezer or (evaporator) fan is behind the panel in the freezer and in most freezers Side by side or standard type have a series of screws or along the outer edges of the freezer panel...some (like in side by side have a freezer fan and a fresh food fan....but not many generally cold air from the freezer is introduced into the fresh food compartment by way of a vent or port hole that aloows free flow of cold air into the fresh food area (but I digress) anyway take out the (several) up to 10 screws that hold the panel in place...if you don't do it soon the fan will go out and then the freezer compartment will iIce over and the fridge will cease to cool...once you pull the panel you will see it ...take it out and take to Johnstone supply, Marcones, or WW graingers for a good price on parts. If you have them where you live.
I hope this helped....If so please rate me. thanks ...the Fang
Posted on Mar 26, 2009
SOURCE: Fridge and freezer sections no longer cold,
you might have coils that are frozen up. Ironic that ice build up will prevent the fridge from working. In my case I could access the coils by removing the panel at the back of the freezer (on a maytag side by side). You then have to remove the ice (let it melt away, do mot try to cut it out...if you do you could damage the coils and there goes the fridge). In my case the problem was caused by a thermostat that was faulty. Easy to replace and all works good. Another issue could be a circuit board (located in the top part of the fridge section). I ended up replacing both parts. not too expensive if you do it yourself (less than $100 for both parts). It took me about 2 hours to do. It helps if you can get a diagram of the inside of your fridge.
good luck!
Posted on Aug 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
Posted on Sep 21, 2009
tunde007
  • 2382 Answers
SOURCE: My fridge freezer is broken.
Hi, you have to examine the cooling unit. If the refrigerator makes a bubbling sound, the cooling unit is leaking or the hydrogen has escaped which is why you are having problem with the freezer section not cooling and as time goes on the fridge section too will stop cooling. Replace the cooling unit.
Posted on Feb 11, 2011
kdrake84
  • 262 Answers
SOURCE: I have a GE side
This is very strange,you have changed out all of the parts that are directly associated with a non defrost issue.
My suggestion would be starting all over. Not changing out parts but troubleshooting wise.
Just fyi.....all the parts can be checked from the mother board, so you will not have to take anything apart to get to the said part.
I have a procedure here on the website that will walk you through a "non defrost issue"
It has a video with a GE refrigerator set up to better explain and to show the customer the parts that are included in the defrost process.
I suggest watching all the videos and then post your questions.....
I believe we will be able to help you.
GE refrigerator non defrost issue with Mother...
This procedure will define the issue with a non defrost issue in all GE refrigerators controlled by
Posted on Apr 12, 2011
How do I adjust the temp on the freezer
Although a make / model was not specified, here is a general guide:
Upright fridges and freezers have a controller which is usually mounted inside the cavity, or at the back of the unit.
Using my own two as an example, the refrigerator / freezer combo, "Fridgemaster", has the thermostat & light assembly at top right interior of top fridge section. Clockwise is warmer and ACW is cold.
The "Kelvinator Trimwall" upright deep-freezer hides it's thermostat at the back left bottom.
The thermostat will have a capillary, a thin copper tube, leading to it.
Jan 31, 2018 | Refrigerators
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Not defrosting
Sounds like you have a bad defrost heater, Changing it is rather involved and you must remove the freezer section back panel to gain access to the heater to check it, it sets in front of the evaporator coil. Good Luck ....
Mar 21, 2014 | Refrigerators
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
