Question about Swingline 48209 Optima ® 45 Electric Stapler
How to open optima 45 swingline stapler - Swingline 48209 Optima ® 45 Electric Stapler
3 Suggested Answers
  • 27 Answers
SOURCE: I have a Swingline Optima 20 electric stapler. One
In that case you can just remove the resistor and check its value with an ohmmeter or digital multimeter.
http://en.wikipedia.org/wiki/Ohmmeter
http://en.wikipedia.org/wiki/Multimeter
Posted on Mar 03, 2011
lbrown1806
  • 488 Answers
SOURCE: swingline optima 40 how do you open and close the
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Posted on Oct 22, 2011
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Staples will not come out of the stapler.
Did you use Optima brand staples? If not, the stapler will not work correctly. You must use their brand of staples or it will continue jamming, and giving you problems. The staples typically found right next to the Optima staplers in the office supply stores. They come in a rectangular metal box and are labeled Optima staples.
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
How to remove the cover of the Swingline 48209 Optima 45
The Optima stapler does top does not remove. To reach the inside of this stapler you have to "pull it in half". Do so at your own risk!
Aug 29, 2013 | Swingline 48209 Optima ® 45 Electric...
How do I remove the lid of Optima 45 stapler
Pry on the bottom of each side and it will come up
Feb 15, 2013 | Swingline 48209 Optima ® 45 Electric...
How to unjam
UNDO THE POWER SORCE AND OPEN THE STAPLE FEED PRY OUT THE JAMMED STAPLES "SMALL SCREWDRIVER SHOULD DO THE TRICK"
Dec 18, 2012 | Swingline 48209 Optima ® 45 Electric...
Swingline optima 40 how do you open and close the stapler?
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Mar 10, 2010 | Office Equipment & Supplies
Swingline 48209 Optima ® 45 Electric Stapler Logo
283 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
