Question about LG (GH22NS30) DVD+RW Burner
My lg (gh22ns30) dvd+rw burner will not read a dvd or dvd rom.
When I put in a dvd or dvd rom disk into the burner it does'nt load the files into the my computer/D drive window when you tell it to open the info on the D drive? As a result, I can't install games from disk or watch movies, etc. Could the burner be shot and need to be replaced? Or, how can I fix the problem? Thanks.
    Sergeant:
  • 275 Answers
You can go to the control panel, then to device manager, click on disk drives. Make sure you have the right one and then delete it. Restart the computer and it should "find" it and install it, that is if it still works.
Posted on Feb 24, 2012
2 Suggested Answers
  • 158 Answers
SOURCE: CD-RW/DVD-ROM BURNER
if you wish to burn cd's which is your burner then you need a software called nero burning rom or any other burning software that lets you burn data or audio cd's or vcd's to burn with if you wish to burn dvd's then you need a dvd burner combo drive which lets you burn dvds
Posted on Aug 13, 2007
DRIVERS FOR NERO BURNING ROM
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
Sep 15, 2012 | LG GH22NP21 DVD-Writer - Internal...
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
Dec 03, 2011 | Sony (CRX230ED) CD-RW Burner
Dvd rom nt working
try dowloading drivers from lgs support site
Jun 02, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
When i load a DVD in the system it is telling that there is no disk it is not reading the disk
if u r sure about properly working of software & os ,u must check internal hardwares of it,like lens motor & its lever.even,sometimes by an easy cleaning of the lens,u can solve thisproblem
May 16, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
It can't read or burn any data on any empty disks (CD-Rom/DVD)! but it can read any other written disks like: programs , Movies , audio disks , data disks just when I put a blank or Empty disk it seems...
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Sep 25, 2009 | LG SecurDisc 8x External Double-Layer DVD...
I am using HL-DT-ST DVD-RAM GH22NS30 I can read disks (CD & DVD) and can able to write in R/W disks. When i tried to write data in CD-R it was failed. I tried Nero6 as well as Nero7 also tried some...
Well I have an NEC DL dvd multi drive and found i was having the same problem. To fix this i installed an nec flashing program and flashed it to the on board rom of the drive.
LG makes this drive so head along to this forum site at http://forums.hardwarezone.com.sg/showthread.php?t=2133420 and read the forums. They will give you specific instructions on where to find this special firmware
Jul 29, 2009 | Computers & Internet
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
LG (GH22NS30) DVD+RW Burner Logo
166 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
