Back to:
Tags:
JVC RX-554V Receiver
JVC RX-DV5SL
posted by HOOSKY on Sep 02, 2006
I recently had a lighting strike and now my receiver turns on and then shows "OVERLOAD" in the display. I have electronics experience and can replace parts but i have limited testing equipment. Can this be a simpple fix ie, power supply capacitor or voltage regulator? I have dwonloaded the schematics on so I am able to find specific parts. Any help is appreciated.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 02, 2006
Not Rated (0)
techman
Rank:Guru Guru
Rating: 87%, 6804 votes
disconnect the output devices and see if it clears. If it does, connect up the disconnected devices up till the reciver overloads again.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on JVC RX-DV5SL:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
The pitch controll for cd deck two on my brand new CM 250...
Receivers
Hi I have the cm250 cd mixer brand new just out the box...
Receivers
what is the correct way to wire a 12 inch orion speaker?
Receivers
I have a Stereo Double Cassette Deck; Pioneer CT-W404R....
auto mute is displayed, no sound coming through for radio...
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
