Question about Samsung Televison & Video
All my tv stations are mixed up and not on the right channels.ie,itv one is on channel 59.model code of tv is ps51d495a1kxxu.serial number isb2td34pb804100n version 02 d495a1kxxu
    Sergeant:
  • 302 Answers
I would try resetting the TV to it's factory setting. Look it up in the manual. Then rescan the channels. If that does not work you might have a bad signal board.
you can get parts for this tv at www.interliquidparts.com
Posted on Feb 25, 2012
  • 12 Answers
SOURCE: Problems setting up
Please post what Make/Model of television you have, and I will gladly help you. Thanks!
Posted on Jan 20, 2008
SOURCE: TV losing its channel memory
Call Acer.
I had he same problem, Acer sent to me a technician who uploaded new firmware to the TV and in about 10 minutes the problem was solved.
Uploading the new firmware goes through a specific interface so unfortunately you can't do it yourself
Posted on Feb 16, 2008
SOURCE: Lost ITV channels and C4
I have the same problem, can anybody help?
Posted on Jul 08, 2008
I've got exaclty the same problem :-/
HELP!
Posted on Nov 21, 2008
  • 1214 Answers
SOURCE: NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Posted on Feb 16, 2009
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
How do I get my HD to work?
if your refering to the built in freeview in your tv it is by tuning to the hd channels, on my tv standard definition itv is just number 3 but itv HD is on channel number 103! is that what you meant by your question?
Jan 23, 2015 | Televison & Video
Hi...juz wanna know wat wud be d possible solution for this tv problem. It lacks some channels and didnt respond correctly to the channel and its station. In other words besides that it lacks some channels...
HI. I guess you mix the expression channel with number. The "channel" is the division in "places" for each transmitter in the entire TV frequency spectrum. The "number" is just the preset number one gives to a certain channel stored in the TV. F.i. on can use number 50 to channel 4, which it the last channel in the lower VHF band.
When you to to "manual" tuning, and you select "4", then you may receive this channel, and assign it to any number you choose between 0 and the max presets possible. (mosly 99). After storing, you can choose another "channel ". It is also possible to choose in H or S. H are the regular B1, BIII, UHF channels. (rsp. 2-12, 21-69). The S band contains frequencies in between and above these bands.
Hope this explanation is of any help to you.
Oct 01, 2014 | Televison & Video
Loss of some channels on 32LD30U B
Weak digital signal. Either antenna or tuner.
May 03, 2010 | Televison & Video
Cannot get ITV or Channel 4 on newly aquired DTV, why is that?
The only thing I can think is happening is for some reason it's ignoring these stations. I suggest you try going to the factory settings for it. Then retune, it might clear the tunner's memory.
Feb 26, 2010 | Televison & Video
My set top box will no longer pick up certain channels such as itv and channel 4 stations !!
My set top box has setup menu, channels, autoscan to scan for channels. They changed some of the channels here after the original switch to digital, and a fresh autoscan was needed to again find the channels that moved. See if your box has autoscan for channels, and do it.
Dec 28, 2009 | Televison & Video
Hello, I seem to lose the (digital) ITV channels in poor weather.
I would get the aerial checked there may be a problem
Oct 04, 2009 | Televison & Video
Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Nov 19, 2008 | Televison & Video
The box super
hi i have the super box has anyone got the new code
Aug 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
478 people viewed this question
Henry  Thomas
Henry Thomas
