Question about Dell Dimension 3000 PC Desktop
Dell monitor monitor comes on when computer is first turned on then goes off several times to black screen and turn it off and on until it finally stays on ,but when it goes to idle mode it does the same thing again
  • nongete Oct 31, 2008
    same problem i encountered with my dell dimension 3000 pc.
  • 22 Answers
Dont buy a new monitor!!!
Check out your pc 1st - is it old? it could be a video card problem.
Posted on Oct 30, 2008
    Master:
  • 788 Answers
Sounds like there is a heat related problem. Probably a bad solder joint somewhere. Could be hard to track and would probably cost you more money to repair and it does to purchase a replacement monitor. 17" LCDs go for around $150 these days.
Posted on Oct 28, 2008
Por error desconcete el sonido del monitor y no
My Dell monitor screen goes black after I move my mouse around to get on my computer. The screen goes black and I have to hit the button on the screen (that lights up the screen) about 18 times until it finally stays lite. I don't get it, if there is a problem with the light why does it stay on after hitting the light button several times?
Patty
Dec 29, 2009 | HP Computers & Internet
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Comp. powers on, shuts down three times then goes into powersave
You may want to check the power supply fan whether it works properly or not. Also, you may need to check your BIOS setup if you had done anything with it.
Jun 23, 2009 | Dell Inspiron 530 Desktop Computer
When the computer is turned on the monitor goes off. Then when I unplug it and plug it back in it comes on and stays on until I turn the computer off and back on again.
My monitor goes black but I can faintly see the images on the screen. It was said here that it appeared to be capacitors. What can do?
May 03, 2009 | Dell E176FP 17" LCD Monitor
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Screen goes blank when I move the mouse
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Dell Dimension 3000 PC Desktop Logo
61 people viewed this question
Alun Cox
