Question about Compaq Presario Computers & Internet
I have a compaq 6820,s and it won't power up, i get nothing, no screen, sound power, nothing at all. I change the power cord and nothing happen. So could anyone out there help me please?
  • Compaq Master
  • 32,281 Answers
Try reseating the RAM modules, If this does not work then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. If the RAM is faulty them it needs to be replaced.
Posted on Feb 25, 2012
How can I fix my hp61 of it won't start screen
You say the battery is charging? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged in? Any damage? Drop? Do you leave the Laptop plugged in while not in use?
Apr 13, 2013 | Computers & Internet
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
My nc6400 won't power up even when connected to a power adapter. How can I fix this?
Since you already tried another power cord (assuming that it was a working cord and for the exact same model). Then I would say your motherboard is dead.
Aug 17, 2012 | HP Compaq nc6400 Notebook
Screen on presario 2500 is black blank and won't change
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 19, 2012 | HP Compaq Business Notebook NX9010
Compaq Presario CQ60 won't turn on
If you already replaced the motherboard then try replacing the power cord. If you meant you replaced the cord already, the it might be your motherboard is bad.
May 15, 2012 | Compaq Presario CQ60-220US PC Laptop
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Compaq laptop power failure
Hello, did you consider thinking that the battery of power adapter cause this?
Nov 13, 2011 | Computers & Internet
I think i shorted out my motherboard with another inverter to powerful now pc isnt coming on compaq 442875-001
Connect a known good inverter and Screen with the laptop's battery removed and power cord disconnected. The motherboard will power up without a screen or inverter connected if it's working. If not check F1 or FS1 on the main board power supply section. Also check the diodes in that area for shorts. Sometimes what happens is the screen or inverter gets plugged in while the battery or power cord is connected. Even thou the laptop is powered off it still has the standby voltage live.
Jul 18, 2011 | HP Compaq Presario F500 F700 and G6000...
Computer will not start
Disconnect battery and unplug from power, test for voltage on power cord and re-insert, hold down power switch. If nothing try battery without power cord. Still nothing (no lights, no sounds) then it may need system board replacing.
Sep 19, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
148 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
