Question about Denon D-C30 Shelf System
Denon DC30 service manual - Denon D-C30 Shelf System
2 Suggested Answers
SOURCE: DC30 Denon cassette deck Drive belt broken
Hi J,
Sorry no solution for you. But I was wondering if you managed to fix yours. My D-C30 just has the same issue. 10 seconds of clicking and reading on another thread it sounds like the drive belt is broken and needs fixing.
Did you manage to find any instructions or spares etc to do this?
cheers
Nick
Posted on Aug 03, 2010
Im after a denon RCD-N8 service manual please? can anyone help? Thanks
Sorry the service manuals are not sold to the general public, only authorized approved Denon repair centers.
Jan 09, 2017 | Denon Audio Players & Recorders
I own 15 garmin dc30 collars and when hunting they are spred out in no specific order over 3 astro 220 hand held units. I am having trouble receiving all of the collars. On one unit i may pick up for...
Hi, thanks for posting your Question..
At times you may experience Problems with a Garmin Astro DC30 Collar. I've heard And experienced reports of the following problems with Garmin DC 30 Collars
Before trying to do a Hard Reset for the Garmin Astro 220 DC30 Collar you should try and identify if it is the collar or the 220 Receiver. the easiest way you can do this is to check your Tracking System with another collar. If the second collar works fine then you can assume that you DC30 is not working as it should.
First i would Check all the basics, make sure the collar is charged.
I also would Delete and Re establish the Dog Collar in you system by going to the Dog List on the menu of the Astro 200, I would probably recommend Resetting the 220 receiver since it is much easier to reset that than the Collar.
Lastly, If these do not fix your problem you should try to "reset" the DC30 by
Removing the Back Plate (silver piece)
While Your looking at the connections for the two antennas, I would check to make sure there is nothing wrong with both the GPS antenna connection, and the VHF Antenna on the collar. Personally I carefully disconnect each and make sure they are both clean and free of Debris and Junk. (good Solid connection here will only help the performance of the collar) You can carefully use a brush or electronics contact cleaner for the VHF antenna (Screw mount) (See images below). I would not put anything into the SMP (square Antenna wire connector)
Removing the VHF Antenna on a DC30
Clean this before re-installing. Very Important to have a good Electrical connection3. Remove the Four Small Philips screws on the outside of the case to access the battery and electronics compartment. Very Carefully Disconnect the white battery connector from the board (see images below). Leave the battery Disconnected for about 15-20 minutes for a full reset, Reconnect it to the board.. (CAREFULLY) Here you Can see the battery Connector for the DC 30 Garmin
Different Angle of the connector for Dc30
As you re-assemble the Garmin DC30, Clean all seals and clean antenna connections.
Clean all seals and connections before re-assebling the Garmin DC30 collar
That is A Garmin DC30 Reset Instructions, and Many times when you are having Problems with Garmin DC30 collars this is the First step Garmin will ask you to do before sending them back.
Here is how to Mark a Location other than your location. For example You might want to mark the Tree before you get to it in case your dogs leave the tree. Most of the time If you are like myself You want to Scroll over and Hit the Mark Button, However that will just Mark Your current Location and not the location that your cursor is.
Here are the instructions To mark a location where your cursor is on your Astro 220.
Press map
Scroll the cursor over to the location you want to mark.
Press (ENTER) instead of pressing Mark.
If you press Mark it will mark your current location..
After you press enter.
It will either Select something that you've scrolled over and you should be able to save that as a Location, (Hint: you can change the name to what ever you want before you save it.)
Or if it doesn't select something it will say "no Map info at this point. Do You want to Mark a location here"
I know it's pretty confusing and counter intuitive, But that's how you can mark a location where you are not at.
If your Antenna's are not too OK,you can get a replacement from the below link:
http://garminastrodog.com/garmin-astro-dog-tracking-antenna-questions/
http://www.hdssupplies.com/garmin.html
Good luck and thanks for using fixya.
Jul 12, 2011 | Garmin Astro 220 GPS
My denon got broken front panel, can i order a new front panel including the plexiglass?
I have service manual of Denon AVR-1705 that has part number list, schematics etc
I'll upload that service manual for you to take part numbers of broken parts in receiver and check it out at partstore.com
Let me know if you need service manual copy.
Thanks.
Nov 27, 2010 | Denon AVR-1705 Receiver
DC30 Denon cassette deck Drive belt broken Are spares available? Are there instruction on how to replace drive belts?
Hi J,
cheers
Nick
Mar 23, 2010 | Denon D-C30 Shelf System
Need instruction manual for denon drw-660 dual cassette deck
http://www.user-manuals.com/advanced_search_result.php?keywords=denon+drw-660+&osCsid=11873a748fd5790e73fdb0587299c24e&x=10&y=14
$10
You may find what you are looking for in another manual. Denon has some manuals on their website www.denon.com. Look for SUPPORT tab, then service manual. On the bottom of that page, they have info for some discontinued models. Read them and you may have the answer to your questions
Mar 15, 2010 | Audio Players & Recorders
I need a Denon AVR-3808 Service Manual
try doing a google search for avr 3808 manual
also try going to denon.com if you need a hardcopy call denon tell them to send you one.
Feb 18, 2010 | Denon AVR 3808Ci Receiver
How to get service manual - Denon M10 (UDCM-M10) - CD Player
I woul try to download it from a reliable site and print or see if Denon sells it
Feb 09, 2010 | Denon D-M10 CD Shelf System
Looking for Denon dra 1025r Service &/or user manual
I have a Denon Dra-1025R operating instruction book,if this what you need and I can offer some info let me know
May 06, 2009 | Audio Players & Recorders
Required free service manual of DENON DRM 740 The system hangs after WELCOME
You can free download sm from elektrotanya:
http://elektrotanya.podzone.net/?q=showresult&megnev=denon&megnev2=740&kategoria=&kat2=schematics
Apr 13, 2009 | Denon DRM-740 Single Dual Cassette Deck
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
