Question about Kitchen Appliances - Others
Need Firepower Add On Furnace 2230 operating Manual
Hi. We have a Firepower add on furnace model # 2230 with serial# 24077 already installed in our home. It did not come with a manual of operation and we need one fast! Thank you.
  • TUFFNUTS Jan 17, 2009
    I also have the same furnace. It was already installed in our home at the time of purchase. I would also like an owners manual. Email address is roesermark @yahoo.com
  • Bruce Troup Feb 15, 2017
    Could you send me the manual I need a picture of the inside of the wood burner to see how the bricks are set up on my 2230 model firepower wood burner email is bgtroup1@windstream.net
You can email me at T.rentnik@yahoo.com i have the firepower 2236......the 2230/2236 is the same manuel.....these are nice furnaces.....i have the manuel just email me
Posted on Nov 23, 2008
Can you please email me the manual for the firepower model 2230 as well? destroyer_134@hotmail.com
Posted on Apr 21, 2014
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
Got induction fan for Volgelzang wood furnace and no instuctions
I don't have one and cant seem to locate one online. You will need to go to a dealer or call them again.
Mar 23, 2014 | Vogelzang Norseman Warm Air Add-On...
If i hook my Aprilaire 400 Manual (not auto/digital) humidifier up straight to a 24v wall outlet instead of to the furnace, will it still work correctly? Or does it need to be powered by the furnace to...
Your humidifier is a bypass type. The only voltage needed is 24vac to open the water valve. Air only flows through the humidifier when the furnace blower is running, and the wet pad will add very little humidity if the furnace is not running and heating the air before flowing through the wet pad in the humidifier.
It is best the water valve is only energized when the furnace is running. Some furnaces have a connector on their control boards labeled HUM for this purpose. Test it's voltage when the furnace is running because some will output 110vac instead of 24vac you need.
Jan 31, 2013 | Aprilaire 400 Humidifier
Firepower furnace model 2242wiring diagram
some FURNACE has the diagram inside of COVERS , please to see behind the covers. However if do not appear please give the mark, model and type of furnace gas or electric
God bless you
Oct 08, 2012 | Heating & Cooling
I'm not sure of the exact model of my Goodman furnace, but here is the problem. The new furnace was installed this summer (2010) and it is mounted in the space under the house in Big Bear Lake, CA....
I suppose this furnace is fueled by Natural Gas?
(Or is it Propane-- Bottled gas?)
Did the Service company leave you any manual, with your new furnace?
and I would think there was a warranty, for assuring you (the customer) satisfaction, no?
Have you called the people who sold/installed it?
What do they say?
If they did leave a manual-- what does it suggest for narrowing down your possible problems?
Like: Low Fuel-- Low Voltage- Filter Changes, Fan switch problems- or ignition failure problems?
For a new furnace, someone should be right there to do a start-up for you!
Let me know what you learn--
Mack B
Jan 14, 2011 | Goodman GMS80903BNA Heater
I have a 2 year old Goodman GMV950704CXBB Natural gas furnace. In the morning when the thermostat calls for heat, going from 68 to 73 degrees, the furnace will start, run great until the temp reaches about...
Well if it takes a while to act up it's probably overheating, drain issues, or a component failure like a weak high temp limit. That unit has a full variable speed blower motor, so airflow is critical for proper operation. What kind of trouble codes are present when it fails?
Mar 25, 2017 | Goodman Heating & Cooling
Dry house with furnace mounted humdifier
Is the furnace fan set on auto or on. You will get better humidity if you keep the fan on. It won't add much to your electric bill because many of the newer furnaces operate the fan on DC voltage. Try it!
Jan 16, 2010 | Aprilaire 700 Humidifier
Need specifications on this furnace.
you need the model and serial # from the unit first
Nov 14, 2008 | Heating & Cooling
Adjusting dehumidifier on furnace
This model furnace does not come with a built in humidifier. Humidifiers are normally an optional add on. If you have a by-pass type humidifier it is none adjustable. Water level is normally float controlled and operation is control by blower circuit. When ever the blower runs the humidifier operates when in the heating mode.
Jan 24, 2008 | Dehumidifiers
Kitchen Appliances - Others Logo
1,591 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
