Question about Oregon Scientific Garden
Iam confused about the rear PtO and the transmission as one calls for type A ****** fluid and the other 90 weight gear oil. Where does the gear oil go in the PTO or is that ****** fluid? and where is
A mechanic told me that the PTO took the gear oil. But it calls for 2 pints of 90 wieght and it barely registers on the dip stick? the ****** calls for 6 quarts of type A ****** fluid. I think that hes got it backwards and I dont want to chance harming the PTO or ******. which is it and where is the ****** and PTO located? Thank you!
  • Oregon Scien... Master
  • 2,478 Answers
Gear oil goes in transaxle and type a in the other system.
Posted on Feb 24, 2012
Testimonial: "thank you for responding ive got it figured out now!"
  • Dennis Key
    Dennis Key Feb 25, 2012
    I download a manual. Only place to put oil is in the transmission. Sorry for pervious answer. Everything is connected to transmission housing.
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
What type of fluid in 1995 Kia sephia standard transmission
I personally run 80-90 gear oil but some manufacturers recommend 30 grade for their boxes ( straight mineral oil) best check it out at a service dealer centre.
Apr 04, 2015 | 1995 Kia Sephia
Does rear end oil and hydrodaulic fluid go in same reservoir
Ford 8n's use a commion sump, rear end, transmission and hydraulics. Ford called for 80 or 90 weight gear lube depending on temperature (winter/summer) about 5 gallons The link below is a great article on proper oil and maintenance....Hope this helps...
< http://www.myfordtractors.com/hydraulics.shtml > Ford Tractor Hydraulic System
Jul 26, 2014 | Ford 8N Tractor
Im a single mom and dont have a owners manual for my voyager, that was given to me. i want to make sure im putting the right fluids in. can you help? it doesnt tell me on the dipsticks like some...
Engine oil for cold climates 5w-30. Warmer climates 10w-30. Any Auto-zone parts store person at the counter would be more than helpful choosing the correct fluids for your vehicle.
Feb 15, 2011 | 1995 Plymouth Voyager
What type tramission fluid to use for 5speed manual-4cyle?
1992 Ford Ranger came with two different type of 5 speed stander transmission's that year.
For a Mazda stander trans it take's Automatic transmission fluid Mercon.
for a Mitsubishi stander transmission it take's Ford manual transmission fluid.
Hope this help's.
Jun 28, 2010 | 1992 Ford Ranger
!992 nissan stanza standard trans fluid
If your referring to the manual transmission where you do the shifting. Your going to be using gear lube, not to be confused with transmission fluid. Which is red in color, they are not interchangeable transmission fluid is only for automatic transmissions. Gear lube is much heavier in weight, you want to get a gear lube 80-90 weight this lube is perferred for your vehicle
Apr 03, 2010 | 1991 Nissan Stanza
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
Feb 09, 2010 | 2000 Toyota Tacoma PreRunner
Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Jul 17, 2009 | 1995 Volkswagen Golf
96 nissan pick up 5 speed what kind of fluid goes back in it?
You use either 75W-90, 80W-90, 85W-90 or 85W-140
Nov 13, 2008 | 1996 Nissan Pickup
Need to change manual transmission fluid
pull the lower plug from the transmission, it will be on the bottom or the side on the bottom. replace the plug after draining and remove the fill plug wich is about half way up the side of the transmission. use 75w 90 gear oil in the trans.
good luck
Aug 31, 2008 | 1999 Jeep Wrangler
Garden Logo
197 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
