Question about Technics SL-MC400 110-Disc CD Changer
Technics SL-MC400, 110 discs in changer, showing no disc message and can' t open front of changer on left side
I had this problem before and was told there is an unlocking code for this product, involving pressing 2 buttons together, I have tried stop and play - this gives me the test mode but i'm not sure where to go from there
SOURCE: Technics CD Changer SL-PD887
this is a standard plug you should be able to get from radio shack or other electronic stores. just take a picture of where the connection is on the unit with your mobile phone and show it to the sales person. cheers, mark
Posted on Sep 28, 2007
  • 112 Answers
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: i need to download a users manual for technics
Web search "Technics SL-MC3 manual" and this pops up...
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/How-To-Guides/model.SL-MC3.H
Please try the search engines first.
Posted on Aug 08, 2011
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
No instructions how do i open to load discs
To open the front panel you just pull it gently on both sides - it is hinged on the bottom. Detailed instructions can be found in the manual which you can download here: SL-MC4 Manual
May 05, 2011 | Technics SL-MC4 61-Disc CD Changer
Technics SL-PD888: Output signal is distorted/overdriven.
I can't find a manual. If it has both analog and digital outputs, compare both for sound quality and report the results. Also try them on different INputs of your electronics to eliminate that as a problem.
Let's examine THAT side, too. What are the components involved and how are they connected?
Feb 21, 2010 | Technics SL-PD888 5-Disc CD Changer
Door will not open,get checking disc message
I solvwed the problem by removing the cover and found 2 discs jammed into the same slot. removed them and put them in the proiper slos, put back cover, gently tightening the screws incase it happens again.
technics 110 cd changer. model sl-mc310.
Dec 20, 2009 | Technics Audio Players & Recorders
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
263 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
