Question about Kenmore Sewing Machines
Thread pin where is the thread pin?
  • Susanne Jeffery Feb 25, 2012
    I need to wind my bobbin with thread. I see the place to put the bobbin and I can't see where to put the thread spool..... I have been a sewer for years
  • Kenmore Master
  • 7,365 Answers
Contact by email sewvacdoctor.com
Posted on Feb 25, 2012
I have a bernina 550. What should I set the tension when sewing with invisible thread?
When I took a quilting class, the instructor had us put the invisible thread spool in a coffee cup behind the machine. Then we taped a paperclip or safety pin at the top-back of the machine (with about half of it above the sewing machine) between the spool pin and the first thread guide. Then we ran the invisible thread through the hole in the paperclip/safety pin and through the remaining thread guides and tension disks. (Technically, we avoided the spool pin.) Do NOT put invisible thread on the bobbin. Then adjust the top tension like you would for regular quilting or sewing.
Aug 07, 2017 | Bernina Sewing Machines
The spool pin on my Brother VX1010 doesn't come up so I can't put a spool of thread on it.
Difficult to say. Some machines have a spool pin that can be pushed down for storage or transport. Your machine may have this ability. Or, perhaps someone has pushed the pin down accidentally. If you can use a needlenose plier to grab the tip and pull up, the spool pin may be fixed. If there is any part of the spool pin still projecting above the machine, you can cut a length of plastic drinking straw and fit it over the spool pin to hold your thread spool. Some sewists use a standalone thread holder (available multiple sites online, etc) that sets on the table behind the sewing machine or some people will throw the thread into a jar and set it behind the machine.
Cone Thread Holder Jo Ann
Jan 05, 2017 | Brother Sewing Machines
For the dressmaker II, the first bobbin, I got through step 1-5 but where the does step 6 go BECUZ that's really trippin me, PLS tell me. And the instruction is not clear at all, I don't understand it
Hi Vicky, I hope this helps you:
1. Remove the slide cover plate by sliding it toward you, and lift
up the bobbin and the bobbin case from the machine.
2. Put the bobbin pin into the hole on top of the hand wheel and
place an empty bobbin on the bobbin pin (spindle).
3. Lift the large spool pin from the back of the machine and
place the spool of thread on the large spool pin.
4. Place the bobbin winder tension clip into the hole in the back
of the machine.
5. Pull the thread to the left and pass it through the bobbin
winder tension disc.
6. Insert the thread through the hole in the bobbin from the inside
out and leave about 3" of thread out. (ensure that the hole on the bobbin is facing upwards)
7. Hold the end of the thread and start the machine, either by
pressing on the start button or the foot control. After the
bobbin winds a few turns, stop the machine and cut the thread
close to the bobbin. (Cut the thread end that is protruding from the hole at the top of the bobbin).
8. Start the machine again and continue winding until the bobbin
is full or the quantity of thread is enough for your needs.
9. Stop the machine and cut the thread. Remove the bobbin from
the bobbin pin.
10.Take out the bobbin pin from the hand wheel and push back
the large spool pin into the slot in the back of the machine.
Good luck :)
Jun 21, 2015 | Euro-Pro Dressmaker 998B
Bernina artista 180 bottom stitch bunching
bunching under the material is bird nesting is a result of loose needle thread tension thread the machine up to the point of threading the needle
pull on the thread and you should have a reasonable resistance to pulling the thread
adjust the tension until you get that then thread the needle
while you may be using the tension settings if there is a problem in the tension plates area , the tension will not get high enough regardless of the indicated setting
bobbin tension can be reasonably loose
correct tension is when both threads meet at the center of the materials being sewn
May 25, 2017 | Sewing Machines
Spool pin not come up
You may have to take the machine apart to get the spool pin. Shake the machine to see if it is loose inside. If you can see the top of the pin a very very strong rare earth magnet may be able to retrieve it from the outside. If the pin is not causing problems inside the machine you can use a thread stand or install another spool pin on the outside of the machine with a pop rivet gun.
Nov 17, 2013 | Janome Sewing Machines
Threading double needle
Double needle sewing requires two threads. Most machines have two thread spool pins, one spool on each pin. Both threads are threaded just like a single thread down to the needle, which is where they separate, one thread through each needle. One exception would be on machines that you can see the tension discs, some have a separating disc between the two outer tension discs, therefore, run one thread on either side of this centre disc. Also in zigzag mode, you must realize that you cannot utilize the full width of the zigzag due to the extra width of the needle path.
<Ray>
Nov 07, 2010 | Sewing Machines
Bobbon thread is too losse /thread breaks no
Clean out the bobbin area.
Thread the machine with the presser foot up. This opens the tension so the thread can enter. Threading with the foot down closes the tension and the thread cannot enter as it should. When you sew, the top thread is loose and cannot properly connect with the bobbin thread to form a tight stitch. The stitching does not hold and pulls right out.
Thread breakage - top thread? Check the thread spool to be sure there aren't any nicks to catch the thread.
When the thread breaks, check the spool pin to see if the thread is unwinding too fast and wrapping around the pin. Thread nets can help stop this. You can find them at sewing machine dealers.
Mar 11, 2010 | Singer Sewing Machines
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Need manual for 11301 barbie sewing machine
Anyone who needs a Manual for this Barbie machine I have it in pdf.
Someone tell me if they want it posted.
thanks,
Bonnie
May 03, 2008 | Barbie 11301 Mechanical Sewing Machine
Sewing Machines Logo
13 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
