Question about Kenwood DDX7019 6.95 in. Car Monitor
Face plate won't close completly
On a drive several weeks ago, I hit the button to load up a cd, the face plate rotated up like it's supposed to, but upon closing, it would not close all the way. Lacks about 1/4-1/2 inch before closing.
Any ideas before I go back to the stereo shop and raise cain. This is the second failure on this head unit in the 2 months I've owned it.
techman
  • 3130 Answers
SOURCE: face plate wont move
First check the power fuse as well as the stanby or always on fuse. then if that does not work Try to disconnect the power and standby line and let the unit reset . This should be done for at least an hour or so.. Good Luck
Posted on Jul 25, 2006
  • 11 Answers
SOURCE: kenwood kdc-x869
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Posted on Dec 16, 2007
  • 11 Answers
SOURCE: Faceplate won't close
Alot, of the radios have a common problem with the connection from the radio's2.gif detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD2.gif and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, the display partially turning on and off, and the face to act peculiar and flip down halfway. In addition, sometimes the face open and close switches go bad, but I've never had to replace them yet. .
robotek
  • 1512 Answers
SOURCE: Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Posted on Feb 08, 2008
zzedly
  • 300 Answers
SOURCE: My Kenwood KDC-7024 has just
It's possible the flexible PCB (more of a cable, really) that connects the faceplate to the main unit has cracks in the conductors. This has been an issue with some of the older Kenwood HUs that have the MASK motorized faceplate. The flex-cable gets bent and pinched enough over the years that it eventually cracks the copper.
Posted on Mar 07, 2008
CD won't load into the 6 disc changer.
Try loading your CD into the first slot of the magazine. Be sure the magazine is completely seated in the player
Mar 27, 2013 | 2005 Lincoln LS V8
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cd stuck reject button won't work
Look at the face plate of the CD drive, if it has a small hole located under the tray straighten out a paper cilp and stick it in the hole to preform a manual eject. Remove any disc inside and close it. Now try to open it normally. If it still does not work it is time to buy a new cd drive.
Aug 06, 2011 | Computers & Internet
I have a 5CD changer stereo system. It is very close to the RS2652 and I use it every day in my classroom. Several weeks ago, it began behaving strangely. First I could only get one or two cds to play...
It very well could be a lightning related issue. From previous experience servicing equipment, I have found that electronic equipment that is hit by lightning acts strangely very comparable to what you are describing. Function switches are performing different functions usually due to shorts from the hit. It tends to act normally for bit, and then sporadically do something completely different from what it is supposed to.
As far as service, depending on the age and original cost, you probably are better off getting a new unit. It has also been my experience even if something electronic is repaired, it still may act strangely doing something else later if it was indeed hit. Unfortunately most electronic repair charges can be rather high, maybe 50.00 hr or so, plus parts and a bench fee just to look at it. I have replaced many items for customers after they had them repaired because of this. Check into your insurance. It you have a higher deductable, it may not be worth it. Insurance companies also tend to charge higher premiums as well. Never hurts to ask, but in the long run a drive to the store might be worth it.
Feb 19, 2011 | RCA Audio Players & Recorders
Cd drive has disk in it and wont open
Look closely on the face plate and around the face plate of the CD drive. (better to have good flash light/Torch while doing this). Close to the eject button (Or around that area) there will be a very small hole (pin hole). Switch off your computer if it is powered. Push a needle or a safety pin into this hole. Take care to push it in straight (not angled). If it does not open in the first attempt repeat changing the angle slightly. May take 3 or 4 tries. But you can definitely get it opened.
Jan 27, 2010 | Computers & Internet
The tray wiyll not stay closed and sometimes will not open or closed.
hi
maybe you have bad contact in micro timing switch, and this micro switch needs cleaning then test run.
Thanks!
Jun 06, 2009 | iLO DVDRH04 DVD Recorder
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Unit opens and closes on its own
I think I got the second half of the solution for this problem. Please look at post "Unit powers down when motorized face opens" for a solution. Seems like we need to buy the ribbon that connects to the face plate to fix this problem.
Jan 21, 2008 | Pioneer DEH-P8500MP CD Player
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Kenwood DDX7019 6.95 in. Car Monitor Logo
69 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
