Question about Sony Handycam DCR-TRV230 Digital Camcorder
The vcr will sounds like its working but no image or sound on screen
When I try to use the VCR mode I can hear it working and it shows the function on the top of a blue screen but no picture, no time log and no audio. The picture works in camera mode. Help, me going to Alaska in 4 weeks and can't afford a new one. Thanks, danny
  • 4 Answers
Hello brother, It looks that is no problem in vcr mode I think you just need to play a head cleaning cassette. I hope it should solve your problem All the best to you Uday
Posted on Sep 02, 2006
SOURCE:
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
VCR shows "PLAY" on machine but doesn't show on TV
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | GE VG4054 VCR
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Magnavox mwd2205 - VCR Function
grace0308, Many of the combo units have multiple video outputs and some, like the SVHS and RGB Component outputs, are for DVD only. Make sure that you are plugged into the proper video output. Play a tape and try them all.
Mar 08, 2008 | Philips Magnavox DVD/VCR Dual Player
PANASONIC PV4022
One way is to manually select the missing channel with the numeric keypad, then push "add." There is also an auto program function puts the VCR into a search mode, adding all channels where a good signal is found. Early VCRs (like late '80s or so) did not have this auto mode, but many later ones did. Also, make sure your VCR is set to the "cable" or "CATV" mode not "off-air" Do you have the VCR manual? If not, recheck your model and see if Panasonic has it online at http://service.us.panasonic.com/OperMan/Default. aspx I looked at at a manual for a PV-4651, and it showed functions which sounded similiar to what you need. Check pg. 10-12
Aug 12, 2007 | Panasonic PV-V4022 VHS VCR
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Black screen
It really sounds like the child lock has been activated. This uaually blocks the keys on the TV, but the remote should work. If your remote doesn't work either, make sure the batteries work. If your remote for the TV can operate other apliances such as a VCR or DVD player, make sure it is in TV mode. If there are any buttons marked TV, VCR, DVD you could try pressing the TV button to set it in TV mode. If the To has a text-tv function there might be more than one button marked TV; one for setting TV mode as posed to DVD operating mode, and one for getting TV picture back when viewing text pages. -Chris
Feb 27, 2007 | Apex Digital AT2008 20" TV
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Sony Handycam DCR-TRV230 Digital Camcorder Logo
137 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
