Question about Vector Black And Decker High Frequency Automatic Battery Charger
What does code F02 mean on the black and decker smart battery charger
I have a black and Decker battery charger that blinks on and off red when I put the lithium battery pack on to charge. What does this mean?
Flashing red light means replace battery
http://www.manualslib.com/manual/16299/Black-And-Decker-5147851-00.html
Apr 18, 2016 | Drills
My 98 blazer acts like the battery is dead but when i hooked it to a battery charger it said it was full and running at 9.1 when it should be running at around 12 then said error f03. so what does that...
It means the battery charger is your problem. Find an old-style simple battery charger, not one of these new "smart" chargers. The simple ones allowed YOU to decide whether to charge or not. Placed more responsibility on you, but a simple charger would WORK for your battery.
At 9.1V, your battery's DEAD.
Jul 12, 2014 | Vector Black And Decker High Frequency...
WHAT DOES IT MEAN WHEN THE FAULT LIGHT IS ON ON MY BLACK AND DECKER SMART CHARGER? i AM TRYING TO CHARGE MY LAWNMOWER BATTERY.
Usually means it is plugged it wrong, or there is a serious flaw in the battery or the mower.
May 18, 2014 | Computers & Internet
What does the code F02 mean for a smart battery charger
It means one of two things. Either you do not have a good connection from the charger to the battery, check and clean the clamps and terminals, or the battery has too low a charge. A smart charger needs to measure the existing charge before it will work.
Aug 24, 2012 | Black & Decker Tools & Hardware - Others
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
What does F01 code mean on a vector vec1097A smart charger
F01- Internal Shorted Cell Battery-(Cannot Be Charged) or
Excessive Load On Battery While Charging (Check Load)
*If this shows it is recommended to take your battery to a certified auto center for evaluation.
This Info Came Directly From The Manual.
May 02, 2010 | Vector Black And Decker High Frequency...
Black/Decker 12 v drill charger will not charge battery. help
If the battery gets warm after being in the charger a while and still is not charged, then the battery is bad
if the battery stays cool in the charger then the charger may be bad
Chargers usually have a light code, I.E. on means charged, slow flashing means charging, and a quick blinking means bad battery
Some chargers have 3 lights and the code should be imprinted on the charger.
hope this was helpful, cb
Apr 15, 2009 | Black & Decker Drills
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Sep 21, 2008 | Electronics - Others
Vector Black And Decker High Frequency Automatic Battery Charger Logo
914 people viewed this question
Top Vector Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Vector Tool and Hardware - Other Expert? Answer questions, earn points and help others
