How do I change the belt on a GE washer WNSR3120?
2 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: GE washer model WNSR3120
If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 21, 2008
How to repair drive belt on GE Profile washer
Contact the GE Washer div. and request a schematic of the machine. It will show you the detailed format for removing parts and construction teherafter.
Mar 25, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
GE washer belt 7 PJE 1303
Please check with the site : wwwespares.com for spares
click this link for tips on replacing belt: belt replacement
Jun 25, 2012 | Beko Hutchinson Poly.v Dryer Belt 9phe...
NEED TO CHANGE THE DRIVE BELT ON GE WASHER
have you got the belt they are a bit tight and need a little stretching before fitting
Nov 27, 2011 | GE WBSR3140DW Top Load Washer
My daughters GE same model washer will not agitate. Stop agitating after just a few months after being purchased. I believe this is a trait from this type of washer. Perhaps GE needs to recall them all...
Premature failure usually is a reuslt of overloading and/or not enough water. So, there is a rubber drive component that fails and some models have agitator pawls, or dogs that fail. Both are fairly easy to change, and not pricey, except for labor..
Feb 07, 2011 | GE WBSR3140DW Top Load Washer
Washer does not agitate or spin how do you change belt wjsr2080t
tip the washer backwards with the help of someone to steady it so you dont scratch it on the wall,then push the motor towards the agitator post and remove the belt,reverse procedure to re-install belt
Aug 28, 2010 | GE WBSR3140DW Top Load Washer
How do i remove the front to check or replace belt
If you need an owner's manual see this site.
http://genet.geappliances.com/DocSearch/Dispatcher
Unless GE has changed in recent years the motor and transmission can be serviced from the rear of the washer. GE engineering did not have a front service panel when I serviced them. Belts usually last a long time, look for a bound water pump or other problems.
Jul 10, 2010 | GE WBSE2090A Top Load Washer
Ge washer making a noise trying to pump water out its a wslp1100doww model. How do u change the belt on the washer? precise instruction in detail would be great
if the belt is not broken you dont need to change it remove hoses from pump and clean the pump out...shopvac the water out of the machine first so you dont unleash it all over your house...
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
My washer fills with water, but won't spin, or agitate. I try changing settings, and all green lights turn on and shut off inmediately!
you have too take it apart and change the agitater belt it is broke you can usally get the belts at home depot or lowes hope this helps
Jul 25, 2009 | GE WJSR2070B Top Load Washer
Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
Selector switch
Clutch assembly
Drive motor
Thank you,
Dave E. (Illeagle)
Jun 21, 2008 | GE Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
