What is the part called on the amana NFW7200TW that has the push buttons to change water temp, speed and soil level. The plastic is cracking.
Whats is the part called on the front of the waster that has the push buttons to control the water tem, speed and soil level. The plastic is cracking.
3 Suggested Answers
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Posted on Dec 11, 2010
Sea Breeze
  • 4655 Answers
SOURCE: Amana nfw7200tw wont change water temperatures. The temp control button wontvwork. The control lock is not activated
All you can do is check the hot water control valve voltage when it should be calling for hot water and coil resistance OHM's 34001131 Hot Water Inlet Valve Here is a parts list=> NFW7200TW10.pdf ( 2,243.13KB ) and a user manual=> NFW7200TW10.pdf ( 16,174.29KB )
APPLIANCE 911
Posted on Nov 22, 2015
APPLIANCE 911
Nov 22, 2015 | Amana Refrigerators
Amana front load washer error E3
https://www.youtube.com/watch?v=fx7Lrj7gEy4
Jul 06, 2015 | Amana NFW7200TW 27-in. Washer Front...
My amana nfw7200tw needs a new drain pump. ive been online trying to find the best deal and i acaully have found a few (for a really great price) that pop up when i type in the washer model # and the
make sure it a drain pump, they same will fit Samsung ,amana and Maytag, make sure it not just stopped up remove it and look at the impellers, i put one in to find out it was the water sensor was soaped up and telling the washer it was full when it was empty and i would get a nd on the front , no drain,Matt, need the answer to fix that let me know.
Sep 21, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
The low water level LED identifies 6kg.
If the product has not been setup before all 3 LEDs will be on.
the power button.
This locks the size
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
How to I reset my Affinity to factory settings? I know you hold down to buttions for a few seconds but I forgot which buttons they were.
Hello, Thank You for using FixYa. I will be helping you today.
push the Spin Speed and Soil Selection keys simultaneously and hold
until you hear a beep. This is no more than 10 seconds
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Elite he5t washer,suds,then f35,no lights over soil level push button. I try start with only water,but the same problem.This will be problem with the sensor?Why I dont have any lights under soil level...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2010 | Kenmore Elite HE5t Washer
Amana side-by-side icemaker buttons on door not working properly
I have an idea whats wrong but it amy be kinda hard to explain to you but here goes.
looking at the selector buttons does it look like the plastic overlay is cracked or worn from where you have made selections over time? what happens is when these selectors crack it causes teh switch to hange in one position. in your case it would most likely be the water button that is the worst culprit. the repair is very simple. you need to replace the overlay which is the sticker that labels the crushed/cubed ice and water. you can order this part through amana using your model and serial number, or post a good model and serial number here and I'll look up the part for you. thx peyton
Jan 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Oct 01, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
