Question about Bosch Dishwashers
Bosch sgs46e22gb/01 service manual
Sgs46e22gb/01 - how to reach electronic water inlet valve
bbtoast
  • 319 Answers
SOURCE: Bosch SHU9915uc/u12 making noise
TJ
I have a possible answer to your diagnostic test, see below, if this doesn't help, let me know, and I will provide more help!
Brian
SHU 991x/992x (Integra) MODELS
To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, SCRUB WASH, REGULAR WASH and RINSE & HOLD), press and hold each program button. When SCRUB WASH program button is pressed, CLEAN light also comes on andan audible tone (?beep?) also occurs.
To start testing, press both POWER SCRUB PLUS and REGULAR WASH buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
SCRUB WASH = Water filling fault (over or under filling)
REGULAR WASH = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), SCRUB WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), REGULAR WASH light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Posted on Jan 19, 2008
  • 1462 Answers
SOURCE: My Bosch dishwasher model #SHU43C05UC/14
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Posted on Jul 14, 2008
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
SOURCE: can't open the door of my bosch sgs46e22gb
Did you make sure child lock is not on
Posted on Oct 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 11, 2009
Whirlpool adp 4404/5. Green light flashes 7 times !! Any idea ?
F7 - Flow-meter failure
Symptom: water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Could be:
1. Water tap closed during water inlet
2. Water inlet hose blocked
3. Water inlet valve (WV1) defective
4. Flow-meter (FM) sends too few / much pulses (less than 10 imp.in 10 sec.)
Flow-meter counts wrong (or the sump is full in less than 30 sec. Causation: Hose felt down and slipped the disc of the valve. The effect is a displacement of the valve tappet).
5. Aquastop defective
6. Flow-meter defective
Dado
Jul 26, 2015 | Whirlpool Dishwashers
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
Power works no water into unit
hELLO THERE:
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 19, 2010 | GE Dishwashers
My bosch wfk 2401 when i start the wash everything is fine then after a couple of minutes it starts beeping the error code 01. i have checked to make sure the filters are cleaned out and that the water...
Hello and welcome to fixya.
I'll start by saying you're right the "01" error code is indicating a fill problem has been detected by the control.
Have you tried just a "cold" water wash ? If not try selecting "quick wash" and on the dial turn it to #1 "cold" in the cotton setting see what happens. Do the same and select #3 "hot". If the error occurs in one and not the other, observe and either focus on the hot water valve or the cold main wash valve ( I don't think it is the cold prewash valve or the error would occur immediately ).
In fact I suspect it is the main wash cold valve ( dual valve ) since you haven't indicated the error occurs during prewash and the hot water valve is energized in prewash by design to help rinse out the detergent no matter what cycle or temp. you selected.
Having said all that, here's what you're dealing with. Even though you appear to have sufficient water flow as you stated you checked for, the electronic control doesn't think it is correct.
There are several factor's which could possibly be causing this error, a couple you've mentioned.
They are...
 Water supply turned off. ( obviously not in this case )
 Water inlet hose filters (strainers/screens) blocked. ( you've said you cleaned them out )
 Water pressure too low. ( must be no lower than 14.5psi and a max. of 145psi )
 Water inlet valve(s) has failed. ( this doesn't appear likely...at least at first, not completely failed based on your description...but the control may think it has. If you have an ohm meter you can check it. the coils should have a value of between 2.7 and 3.3k ohms. That means 2700ohms and 3300ohms. If not within those values the control will detect the value being incorrect , hence displaying the "01" error. Change the valve, Bosch part # 265772, or repairclinic.com # 467537.
The Hot water valve if need be is Bosch part # 171295 or repairclinic.com # 423900 )
 Control module has failed. ( Not very likely either...but possible...if not the valves. )
Let me know what you find as I will watch for your reply here. Thanks for visiting "fixya". Please take a moment and rate the info provided for you here today.
Let me know if you require further assistance.
Thanks and good luck.
macmarkus :)
Jun 12, 2010 | Bosch WFK 2401
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
1e error appears after start
It is an inlet error. Normal water level is not reached after 10 minutes.Check the following:
  1. The Water Supply Tap is closed.
  2. The Water Supply is shut off.
  3. The Inlet Hose is kinked.
  4. The Water Pressure is very low. (below 10 psi)
  5. The filter of Inlet Valve is clogged by impure water.
  6. The Hall sensor is OK.
  7. The Impeller of Air Guide is bound
Remedy:
  1. Take action on Water Supply device.
  2. Measure the electric resistance of Inlet Valve. (950-1300 ohms)
  3. Clean the filter of Inlet Valve.
Oct 20, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Keep on getting the IE erorr
Error code IE means an water inlet error. Correct water level is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Make sure water supply tap is open and not frozen. Check and clean water inlet valve from debris. If the issue persists, replace water inlet valve.
Oct 18, 2009 | LG WM1814CW Front Load Washer
I have an error code of 1E on my LG dishwasher what does this mean and how do I fix it?
1E error is Not reached to the normal water level in spite of 10 min. water supply
POSSIBLE CAUSE REMEDY FOR ERROR OCCURRENCE The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Remedy Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 26, 2009 | LG Dishwashers
Keeps alarmimg 1E on my Lg Dishwasher
Inlet water error 1E
Sep 24, 2009 | LG Dishwashers
Dishwashers Logo
131 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
