Question about HP L1706 17" LCD Monitor
HP L1706 LCD Monitor - 'No Signal' Problem
The monitor displays 'no input signal' when properly connected with good cable and working PC. When the VGA cable is unpluged, it says 'check VAG cable'. What could be wrong?
  • 1 more comment
  • Anonymous Dec 04, 2008
    i have the same problem,, i wonder weather it is the problem with the vga pcb or power pcb inside,,
  • Anonymous Apr 27, 2009
    May I know what memory you refer to? Is it PC's main RAM?
  • Frankie5 Apr 27, 2009
    May I know what memory you refer to? Is it PC's RAM?
Try to replace your memory.
Posted on Feb 24, 2009
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
No input signal
Hi there.
It could be a connection problem between your monitor and your PC.
On the back of the monitor, you will see a VGA cable (usually blue color), it looks something like this:
Make sure that this cable is connected properly to your monitor and the other end to your computer.
NOTE: Those 2 round things are its screws, you have to turn them to remove the cable and turn them again from opposite direction to hold the cable in place.
Thank you. Let me know questions.
Aug 21, 2011 | HP L1706 17" LCD Monitor
My monitor HP L1706 does not ignite but the green light blinks
Your screen is in sleep mode.
Its does not receive a signal from the pc.
Check for loose connections or a damaged cable.
Your monitor could also have a defect internal.
Maybe also your graphic card in the pc.
Good luck.
Mar 03, 2011 | HP L1706 17" LCD Monitor
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
Monitor switch on light flashes and no image??
HELLO, CHECK THE VGA CABLE THAT IT IS FULLY INSERTED AND SEE IF IMAGE COMES UP
Nov 18, 2010 | HP L1706 17" LCD Monitor
My HP Monitor Model No: L1706 problem
I sure sounds like you have backlight problem, since when the VGA cable is connected the power LED turns GREEN and blinks when VGA cable is disconnected, it means the video signal is getting to the monitor OK, so more likely the problem will be in the monitor, but just to be sure, you should also try this monitor with another PC first.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | HP L1706 17" LCD Monitor
I have the same problem. "No Input Signal"
may be the power button get stuck when you pressing to switch on.just change the power button cable with reset button and see. also chek the **** aslo just remove it and clean it and fix it again.
Sep 10, 2009 | HP L1706 17" LCD Monitor
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
HP L1706 17" LCD Monitor Logo
464 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
