Question about Whirlpool ED2KVEXVQ (217 cu ft) Side by Side Refrigerator
Whirlpool ed2kvexvq water dispenser leaks drip
The frig was bought new 2-22-2012. After filling a glass with water from the dispenser the plastic tubing continues to drip.
  • 8 Answers
SOURCE: whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Posted on Mar 22, 2008
  • 3 Answers
SOURCE: When I use the water
possable broblem with water volve,but you need to cal to professionals
Posted on Sep 26, 2008
aasc
  • 1606 Answers
SOURCE: OUR TOP MOUNT WHIRLPOOL FRIG IS DRIPPING WATER
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Sep 26, 2009
Testimonial: "THANK YOU VERY MUCH. YOUR SOLUTION WAS SPOT ON. I USED ONE OF THOSE COPPER GROUNDING WIRES TO PUT IN THE DRAIN HOLE AND WRAPPED END AROUND BLACK TUBE."
  • 105 Answers
SOURCE: in-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Posted on Nov 21, 2009
  • 1218 Answers
SOURCE: Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Posted on Mar 04, 2010
Why is there water dripping from the bottom of the water/ice dispenser
The solenoid valve that controls the water dispenser is leaking internally. It will be a double valve (one for ice, the other for chilled water) located at the bottom of the frame in the back of the unit. To find it, just trace where the plastic tubes originate from.
Easy to replace.
These leaks are sometimes caused by particles getting trapped on the valve seat. This can be prevented by use of an inline water filter on the copper supply line.
Oct 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Good day,
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Whirlpool ED27DQ water dispenser leaks after getting a glass of water, how do i fix this problem
Aug 22, 2009 | Refrigerators
Ice/water dispenser drips after using
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water leaking from water dispenser
replace your water valves one for the door disp is leaking
Feb 16, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool ED2KVEXVQ (217 cu ft) Side by Side Refrigerator Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
