Question about Gateway Computers & Internet
Need to renew ip address for my emachine T3516
    Scholar:
    New Friend:
  • 84 Answers
To change your IP address, check your IP provided by Internet Service Provider(ISP) is static (or) dynamic. If you have dynamic IP, then change your IP address by following the steps:-
1)Clear all cookies and cache file from your browser.
2)Go to Start->Run->Cmd->Press Enter..
Type in "ipconfig/release" for Current IP address and then type "ipconfig/renew" for New IP address.
3)Either follow step 2 or Simply restart or unplug your modem/router .
Doing either step 2 or 3 will change your Dynamic IP address. And And use the site IP-Details.com to check whether your IP is changed or not.If you have a static IP contact your service provider and request him for a IP change .
Posted on Jun 04, 2013
  • 749 Answers
Just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Posted on Oct 28, 2008
Renew ip adress
OK. You need to reset the modem to renew ip address from the current one.You can't reset the ip address using the router reset method.So reset or switch off the modem and then switch on it.Then new dynamic ip address will assign will be generate for your connection.Check ip address using the site Ip-Details.com before and after resetting modem...I hope you will get the answer by my reply.
Jun 15, 2013 | TP-LINK Computers & Internet
Emachines T3516 speakers sound scratchy
This is an itchy problem. Try installing a program called Calamine.
Reload latest audio drivers for your system.
May 12, 2012 | eMachines T3516 PC Desktop
My emachine kav 60 wont connect to internet it says connected but has limited use and the reason is because it can not renew ip address
Try goto start - all programs - accessories - command prompt
Then type
msconfig/release and press enter
then type
msconfig/renew then enter again.
Hopefully this should work and good luck
Aug 22, 2011 | Computers & Internet
How to release and renew the IP address in Win Xp.
Go to start
Go to run
type cmd
to renew the IP command is
ipconfig /renew
to releaed the command is
ipconfig /release
May 03, 2010 | HP Pavilion dv6000z Notebook
My emachine netbook was just stolen. can it be tracked by its IP address
Unfortunately the IP address can easily be renewed, and assigned a new number.
Mar 09, 2010 | eMachines eMD620-5133 Notebook
Wrong ip address. No fix w/ipconfig/renew
192. is the beginning of a default gateway IP address and is usually only assigned when you are using a router. I recommend connecting to your router.
Jan 22, 2010 | E-Machines eMachines Desktop PC
IP ADDRESS IS WRONG CANT GET ONLINE
Tips:If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
Oct 23, 2009 | E-Machines eMachines Desktop PC
I need a disk for T3516 desktop pc and I can"t find it
I do not believe emachines computers come with restore disks. You will need to contact the place you purchased your computer to see if they can get you one, or you will need to buy a windows disk to reinstall. You can download all the drivers for your computer from emachines.com.
http://emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3516
Click on downloads to see the drivers for your computer!
Jun 28, 2009 | eMachines T3516 PC Desktop
Emachine desktop
I suspect your cable modem is looking for the MAC address of your compaq's NIC. if you run IPCONFIG /ALL on the Compaq (Start run, cmd <enter> then IPCONFIG /ALL <enter> , you can get the 12 digit MAC address.
In the router setup, there should be an option to CLONE MAC address, put in the MAC address of the COMPAQ. Then release and renew the IP address in the Router from the cable modem. The router should then get a valid IP address from the cableand you should be able to connect both systems to the router and surf.
Jun 29, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
274 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
