Question about Tools & Hardware - Others
Porter cable 352vs manual
Hi , I need the manual for a Porter Cable 3X21 Belt Sander
My Porter Cable 352vs Belt Sander was clogged from sanding epoxy, wet wood, something like that. No dust collection at all.
I had to remove 4 screws on the housing, one screw under the front handle and another below the rear handle. The housing came out very easily (with a little wiggle). Pay very close attention to where the position of your plastic fan housing sits. It will only be installed in one spot.
http://www.ereplacementparts.com/images/porter_cable/352_TYPE_1.pdf
The pdf diagram was not exactly correct on the housing placement.
Once opened, The wood and epoxy were caked in everyplace. I brushed them out and replaced the screws.
Good as new.
Good luck.
Posted on May 07, 2013
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
Cone10Soda
SOURCE: porter cable 352vs belt sander wont run....
The very first thing I would check is the condition of the motor's brushes. I'd bet just about anything that they're just worn down passed the limit length. I have the same model PC belt sander... and have used it to do that very same task... I came upon your query because I'm shopping for new brushes. This is a very easy fix by the way.
Posted on Jun 11, 2009
  • 1584 Answers
SOURCE: I have a Porter Cable 352VS Type 4 sander needs bearings.
You need special pullers for these, you will have to take it to a power tool repair shop.
Posted on Jan 26, 2010
  • 4088 Answers
SOURCE: After installing new belt, on Porter Belt Sander
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Posted on Feb 13, 2010
rowdy45176
  • 2176 Answers
SOURCE: Porter Cable 362 belt sander - the paper slips off
there might be a buildup of sawdust in the tensioning mechanism or the yoke might be bent. I would look at excess buildup in the mechanism first. there are 3 screws on the outside of the tool so you can remove the assembly as a whole. try and clean as thoroughly as possible. the mechanism should move freely and "snap" when lever released.
Posted on Jul 19, 2010
Testimonial: "Thanks for the idea - we will give it a try!"
Please help me find a free owners manual for my porter cable 352vs belt sander
The ServiceNet site has the manual for most Porter Cable power tools here: http://servicenet.portercable.com/ . The 352VS documentation is here: http://servicenet.portercable.com/Products/Detail/352VS . Look in the right hand column for the Instruction Manual; you'll see an option to download a PDF or have the manual sent by email. However, you need to look at the sander and attempt to find the Type number. This will be on the label with the model and serial number. There are 7 different belt sanders that were released with the 352VS model number. Use this number to get the details for your sander. The direct link to the manual for the Type 1 version, today, is http://servicenet.portercable.com/Products/GetDocument?docName=EnA00111.pdf&productId=55856&productType=12187&documentId=32863&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/Porter-Cable/EnA00111.pdf .
I hope this helps.
Nov 20, 2015 | Sander Tools & Hardware - Others
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
Have a porter cable 3x21 belt sander and the sand paper keep rolling off the wheels
on the front wheel , there is a screw that you can adjust ,, that will adjust the tracking of the front wheel, the rear wheel is stationary , once you have the new belt on, locate that screw,, and just click the switch as you adjust it,, once adjusted, you will see that it tracks straight and won't fall off
Aug 26, 2011 | Porter Cable Garden
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Jan 26, 2010 | Porter Cable 3" x 21" Electronic Variable...
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
162 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
