I don't know if this will help but i found this by doing a little research. Note: Picture Dark, abnormal, Changing Color Temperature Clean the Spark Gaps on each CRT PWB. Remove the Cap, clean the contacts with thin fine sand paper, blow out, reseal hope it helps.
I,m pretty shure the problem is the lamp, just replace it and it should correct the problem
If the set is working on the video inputs, then it has be be an issue with the input source or the tuner or tuner control circuit in the set. If it was a bad lamp or a spark gap problems you would see a problem no matter what you hooked up to the set.
