Question about Panasonic Viera TH-42PX80U Plasma TV
No power power button flashes 7 times
  • Panasonic Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck
Posted on Feb 24, 2012
Lights flashing 7 times
Never heard of 7 flasjhes.
Five flashes = No Print Head Installed. Install or re-install.
Eight flashes = Waste ink absorber* almost full. The printer has a built-in waste ink absorber to hold the ink consumed during Print
Head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the R R ESUME/CANCEL button to clear the error so printing can continue for a while.
A longer term RESET IS possible BUT without changing the blotters, you're exposed to ink eventually running out of the printer without warning but... if you still want to continue, here are the reset instructions. Good luck!
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green.
Now press the resume button 4 times and then the power button. You've just reset the waste ink counter. Good luck. Just hope it doesn't come back to bite you!
Aug 31, 2014 | Canon PIXMA iP2000 Photo Printer
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My canon ip1880 printer orange light flashing 7 times even after I have installed both my cartridges correctly.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Oct 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
Cannon pixma ip1700 not printing
1. Turn off printer
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error 22
1. Turn off printer
8. Your printer should respond as normal..
Jan 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
On Canon S9000 A3 inkjet printer error light flashing to indicate 'waste ink tank nearly full'. Can I fix this myself?
1. Turn off power.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Dec 04, 2008 | Office Equipment & Supplies
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Panasonic Viera TH-42PX80U Plasma TV Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
