Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire diswasher dead
Washed a load. Next load no buttons or lights functional. Power to both circuit boards. Purchased 10/04/07 - picked up 1 week later. Only days out of warranty?
    Scholar:
  • 89 Answers
I've ordered several parts from repairclinic.com, excellent site for figuring problems and getting parts, generally much cheaper than anywhere else. Here's the link for dishwasher: http://www.repairclinic.com/0047_9.asp
You didn't list the model #, so make your selections as needed.
Posted on Oct 28, 2008
    Genius:
  • 1,605 Answers
It happens all the time.
sometime is hours after the warranty. (that was calculated by the manufacture).
check local service center, you need a control panel replacement.
not that difficult to replace. just need the replacement infront of you to connect the right wires.
good luck
Why can't I get my new control board for my Frigidaire affinity dryer to work?
Hey tim bryant, thanks for your post!
I understand that you have installed a new board inside of your Frigidaire dryer, AEQ6000ES2, and on the new board the lights blink. I would recommend a reset on your appliance which can be done by disconnecting the power to it for roughly ten minutes. If that step does not correct the issue I would seek professional assistance for the repair of your dryer. I hope that is helpful. -Matt
Aug 13, 2014 | Frigidaire AEQ6000ES Electric Dryer
Washed clothes last night, unloaded them and put another load in. The light stays on when the door is shut and the power button will not work. We have not lost power.
Switch off and check the drive, check for friction or humming from any section. If so it can be due to fault in the board, fault in the inlet valve or drive circuit.
It is best to trace the power to the main control board to confirm the circuit and if there is no output it can be related to the board. check the door switch which must close circuit for activation of the program.
Feb 24, 2013 | Washing Machines
Is there a reset button on the dishwasher for the Fisher Paykel DD 605. I washed a top and bottom load, nothing unusual about the loads. The dishwasher just stoped and there is no power on either of the...
If there is no power on both the drawers then 2 things
1. the circuit breaker on the mains power supply feeding the dishwasher has tripped
2. the power board that feeds the drawers is faulty. This is located at the base under the bottom drawer.
The drawers won't open because the power has failed mid cycle and the drawer seal actuator motors are locked in down position.
You can force open the drawers but this could require some mechanical adjustments to the actuator yokes if the two sides are out of alignment when power is restored. In any case you will have to force open the bottom drawer to get access to the power board. The part looks like this but may not be the one specific to your model. You will have to contact a parts dealer local to your area.
The only reset function available is to turn the mains power off and back on.
Hope this helps. Please rate the solution if useful otherwise post a comment.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Model mdb7601awb diswasher . Nothing works , no buttons torn on or work when pushed, no action. 1.Have checked power to unit and is ok 2.checked door switches (2) and both work properly. 3. no visual...
I have had the board replaced 5 times and the entire dishwasher replaced once. It was necessary to go to the state attorney general to get Maytag to extend the warranty. Just called the service center for the sixth time, after this the warranty will be gone and will replace with something well built.
May 12, 2009 | Maytag 24 in. MDB7601AWS Stainless Steel...
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Oct 17, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
203 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
