Question about Cameras
My Casio ex 257 lens has been reporting LENS ERROR on the screen. It self corrected one and now the lens is incompletely closed. Is it fixable?
3 Suggested Answers
  • 374 Answers
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Posted on Mar 30, 2008
  • 11967 Answers
SOURCE: my casio exilim EX-Z550 reports a "lens error"
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 02, 2011
Lens error report comes on screen. The camera fell from hands on to the floor. Please suggest a service centre in mumbai.
Sorry to hear about your misfortune, but you may find that if you do find a repair center, the cost of repair may approach (or actually exceed) the current value of your camera. If you can't find a repair center with reasonable cost, here are some last resort troubleshooting steps that you can try that may correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 26, 2011 | Casio Exilim EX-Z750 Digital Camera
I cannot open my casio ex-z77, when i try to open it, it is always retry power on or sometimes lens error, how can i fix it?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 14, 2011 | Casio Exilim EX-Z750 Digital Camera
Lens error
inside the lens their is strip ,its broken inside change it
Jul 09, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
"Lens Error" on Exilim Casio 8.1 mega pixels EX-z9
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 22, 2008 | Casio Exilim Zoom EX-Z80 Digital Camera
CASIO EXILIM EX-Z700 Lens Error
The only way to fix a lens error is to send it into repairs. Call them at 800-706-2534 option 2 and they will tell you the closest place to send it to.
Sep 14, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Casio lens error
When I power up my Casio Exilim Z750, it begins to start up, the lens extends, and then it says, "Lens Error" on the screen and shuts down?
Robin
Jul 02, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio Exilim EX-Z70 lens error
yes I can help you lens zoom motor is out or the gears are stripped. goto www.digitalcamrepair.com for more help.
Jun 12, 2008 | Casio Exilim EX-Z750 Digital Camera
LENS ERROR 2 on my Casio Ex-V7
I read on the Casio website that this is due to an impact, meaning, the camera must have fallen or hit something really hard and strong.
Lens error 2 indicates that there is something wrong in the lens assembly. One possible damage concerns the image stabilization mechanism.
I also own a Casio EX-V7. My sister dropped it so hard that a dent has appeared on one of the front corners. Everytime I switch on the camera on record mode, LENS ERROR 2 appears for a few seconds.
Despite this, I can happily use the camera as usual. However, it's just annoying to see the Error.
I'm planning to bring it to a service center within a month from now.
May 26, 2008 | Casio Exilim EXZ75 Digital Camera
Lens error
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Apr 28, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera shuts off lens error
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
