Question about LG Televison & Video
Tv (lg 42ly95) turned off whilst watching. No won't turn back on. Fuse ok. No lights on front panel.
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Posted on Apr 02, 2008
SOURCE: turn signals and flashers
Hello I had the same problem on my 04 monte. After changing bulbs ,checking wires etc. I finally took it to the dealer and they found out it was the hazard switch. After swapping it with a new one all lights, dash etc started working again and have not had another problem
Posted on Sep 05, 2008
plopit40
  • 16 Answers
SOURCE: LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at plopit40@yahoo.com
Posted on Nov 15, 2008
SOURCE: Tail lights don't work on 1998 Chevy Silverado.
check the wiring from the tailights back to the fuse panel, it sounds like an open connection. if i recall correctly check under the dash on the drivers side near the fuse panel for a bunch of wires in a bundle and look carefully for a wire or two that are cut/shorted/or seperated, you can also check under the drivers side kick panel by the hood release.
Posted on Feb 17, 2009
  • 25 Answers
SOURCE: JVC 62" tv cut off and won't turn back on. red light blinking?
rob52078 is right on the money. You need a new lamp. I usually reccommend getting lamps like the TS CL110UAA for dlplamps.com
Posted on Apr 16, 2009
My 42lh30 lg tv was on the kids where watching movie on xbox then the tv and xbox just turned off. and will not come back on. the xbox is working. but there is no red light saying the tv is getting power....
Possibly you've had a power cut & a fuse associated with the TV has blown. Have you checked the fuse in the TV plug? If that's ok then probably a fuse internally in the TV has blown or something more serious has blown in the power supply
Aug 25, 2013 | LG M4201C-BA 42 in. HD-Ready LCD
My back red lights won't turn on when i when u turn my front lights
look for a fuse that says brake .fuse panel normal driver side under dash or under hood depending on what your driving.sounds like burned fuse to me
Mar 30, 2013 | Cars & Trucks
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Our brand new LG TV loses brightness whilst you are watching a programme.
Check to make sure that eco mode is turned off. It will sense the ambient lighting and if it is bright, the TV will be bright so if you are seeing the brightness change...check that setting first.
Jul 31, 2011 | LG 47LH40 47 in. LCD HDTV
I have a 1 year old Sanyo Vizon HDTV and was watching a show when it suddenly just shut off and would not go back on again. No storms or any other power surges and it is hooked up to a real surge...
Hello
If there is no power indicator LED lights up when the set is sitched ON, the power regulator section inside your TV is faulty. There is a fuse [glass cartridge type]; on the power regulator board. If this fuse blows OFF the set won't switvh ON of the front power light won't light up. Check this fuse first. You can locate it at its power switching regulator board inside, where the AC power goes straight to it after a filternig circuit. If the fuse is blown out, replace ti with same rating. It ratings will be marked either on its edge rims of on its body by colour code lines. Replace the the fuse; if it has blown out, and switch ON the TV. if the replaced fuse also gets failed, do not put any fuse after, the power supply section has some short with it. It is best to replace the power supply board as a card absis; rather than making "surgery" to it. Some components in it will be very difficult to get too. You can buy a new power board from /Vizio Authorised Service Center at your town. OK.
Jul 14, 2011 | Televison & Video
My TV just turned off and the red power light started to blink, why?
In most cases this error will dissapear by switching your television off at the wall and then switching tv on (via power button on TV front/side panel) "Whilst still switched off at wall outlet"
This will discharge all capacitors inside the TV
Now turn TV power button off then switch back on at the wall outelt then try to resume watching TV.
This solution may clear the blinking red light however if it does not it could be a more serious issue such as a blown fuse or even blown control circuit on the TV, In this case you should decide whether a repair is economical or to replace the TV.
This solution is based assumption this a CRT television and not an LCD.
Hope this helps
Feb 28, 2011 | Toshiba Televison & Video
I've a lg 42ly95 the picture blacks out after 10/20 mins the sound remains,turn it off for 20 mins then back on picture ok,then the process starts all over again,sometimes if i put dvd on after the fault...
The problem. Comes down to a buffer board. KLS-420BDR-A This is the part number of the one in the TV which is hard to get as this looks like a common fault.. But there is any buffer board out there 6632L-0394C KLS-420BDL-C
KLS-420BDL-C Which the (c) is the(a) board main board .. Happy fixing people
Lg 42ly95 no picture fix
Feb 13, 2011 | LG Televison & Video
Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Mar 22, 2008 | Televison & Video
Televison & Video Logo
44 people viewed this question
Computer Repairing
Computer Repairing
